Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Chrysler 300 & All LX Models Forums > Problems / Dealer Service
Old 10-27-2009, 03:59 PM   #1 (permalink)
Points: 1,854, Level: 1 Points: 1,854, Level: 1 Points: 1,854, Level: 1
Member Number: 12209
Exclamation Problem - Going over bumps ABS/Brake light blinks
Here is my problem. I have a 2005 300c with about 70k miles. When I go over bumps or rough road especially at highway speeds, the brake light, abs light, and the esp bas light all blink on for a few seconds and when that happens all the interior lights and gauges go out. The Nav radio screen goes dark, the rpms and speedometer drop to 0 and the fuel to E, but then all go back on after a couple of seconds, during this the car is still running fine, very weird if you ask me. Has anyone seen this before or have any idea what it might be or even anything I can check.
Thanks
gatzby143 is offline
Old 10-27-2009, 05:50 PM   #2 (permalink)
Points: 5,459, Level: 1 Points: 5,459, Level: 1 Points: 5,459, Level: 1
robaustin's Avatar
Member Number: 11195
You can check for codes using the "key dance" procedure. If a code is shown, it may indicate the source of the problem. It sure sounds like a bad connection somewhere in the electronics.
Magnesium Pearl
Hotchkis Sway Bars
22Elite Console Cover & door elbow pads
Edashkit Real California Walnut Kit
BT catch can & pink thingy replacement
Diablo Predator CAI + 91 tune
no name CAI, similar to Air Hammer
MotoRad 4127 Thermostat
Conti's
robaustin is offline
Old 10-27-2009, 07:03 PM   #3 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
yeah sounds like a loose wheel speed sensor
Mr. iNCREDIBLE is offline
Old 10-27-2009, 07:38 PM   #4 (permalink)
Points: 741, Level: 1 Points: 741, Level: 1 Points: 741, Level: 1
Member Number: 23719
sounds like a loose connection to me too. I had a similar problem and I finally fixed it by making sure my positive battery terminal under the hood had a good connection.
Big Daddy D 300C is offline
Old 10-28-2009, 07:22 AM   #5 (permalink)
Points: 17,687, Level: 1 Points: 17,687, Level: 1 Points: 17,687, Level: 1
CUEBALL's Avatar
Member Number: 3447
One more place to check that happens, and to me also:
Check the wheel nut holding the half shafts in for looseness. The big one.. I think its 32mm right off hand. SOmetimes they come loose, especially the left side, and the half shaft moves enough to throw the lights you have
Could be any one of the above suggestions, but I imagine the code you'd get would be "wheel speed sensor" as Mr I alluded to.
CUEBALL is offline
Old 10-28-2009, 02:00 PM   #6 (permalink)
Thanks for the suggestions. I checked the codes but nothing came up. I guess they dont store the codes in memory for the ABS and Brake lights. I will check the battery terminals just for the heck of it but my guess is the wheel speed sensor like others have stated. Otherwise off to the dealer for a screwin'. Thanks again
Old 10-28-2009, 04:04 PM   #7 (permalink)
CUEBALL's Avatar
Member Number: 3447
I would try to jack up the rear and see if you can hand turn the big "bearing" nut before they charge you your arm at the dealer. Just a suggestion.. might be an easy fix that costs you 500 bucks at the dealer
CUEBALL is offline
Old 10-28-2009, 04:23 PM   #8 (permalink)
Points: 12,680, Level: 1 Points: 12,680, Level: 1 Points: 12,680, Level: 1
UK CHRYSLER 300C's Avatar
Member Number: 12398
I serviced mine a couple of weeks ago and the left rear wheel had some play,I gunned the sucker up and the play is no more,same with proper jags(not ford ones)they need to make the left side left hand thread so it tightens as it rotates not loosen,know what i mean?
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
and a f00ked up immobiliser that Chrysler UK took 6 weeks to fix..WTF
UK CHRYSLER 300C is offline
Old 10-28-2009, 09:29 PM   #9 (permalink)
CUEBALL's Avatar
Member Number: 3447
Yeah, I was surprised the left side was a right hand thread when I tightened it up. Mine was so loose that I did about 10 turns by hand before I got the socket out...
CUEBALL is offline
