abs bas esp U1419 Code - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 22 (permalink) Old 11-18-2009, 07:32 AM Thread Starter
Points: 1,367, Level: 1 Points: 1,367, Level: 1 Points: 1,367, Level: 1
I have a 2006 300c And Yesterday the ABS BAS ESP light came on, I had it scanned and its pulling a U1419 Code.. No one knows what this is.. I used my scanner tool and erased it.. Comes back in like 1 min
HELP!
beachthrottle is offline
post #2 of 22 (permalink) Old 11-18-2009, 07:38 AM
Administrator
Points: 466,279, Level: 1 Points: 466,279, Level: 1 Points: 466,279, Level: 1
Rambit's Avatar
Car: 2005 300C SRT8
I can't find that code anywhere either. Are you positive that's the right code? Try pulling fuse #11 for starters.
Bernnie
Headlights etc...
Rambit is offline
post #3 of 22 (permalink) Old 11-18-2009, 07:41 AM Thread Starter
I used my Diablo tuner. to pull the code and it says U1419 Just check again.. It clears it out then in like 1 min It comes Back.
Where is Fuse 11 ?
post #4 of 22 (permalink) Old 11-18-2009, 08:05 AM
Administrator
Rambit's Avatar
Car: 2005 300C SRT8
Where is Fuse 11 ?
It's in the Front Power Distribution Centre...
Bernie
Rambit is offline
post #5 of 22 (permalink) Old 11-18-2009, 10:49 AM
Banned by AutoGuide
U1419 = implausible Data Received From Ocs Sensor 3 - Left Front
this is an Error from the passenger seat Occupant Classification System (OCS)
the left front sensor on the seat has a problem, verify that something hasn't slide under it some how.. Coins will fubar the readings.
Mr. iNCREDIBLE is offline
post #6 of 22 (permalink) Old 11-18-2009, 01:10 PM Thread Starter
Now I get U1417 Code
post #7 of 22 (permalink) Old 11-18-2009, 01:15 PM
Banned by AutoGuide
U1417 implausible Left Wheel Distance Signal Received
u1418 implausible Right Wheel Distance Signal
u1419 implausible Data Received From Ocs Sensor 3 - Left Front
u141a implausible Data Received From Ocs Sensor 2 - Right Front
u141b implausible Data Received From Ocs Sensor 4 - Left Rear
u141c implausible Data Received From Ocs Sensor 1 - Right Rear
sounds like the ABS Module is having an issue, still have a warranty? it may need to be re-programmed or calibrated.
post #8 of 22 (permalink) Old 11-18-2009, 01:21 PM Thread Starter
No Warranty. 60k Miles.. Any Idea what I can do to check ? should I go back to my factory tune ?
post #9 of 22 (permalink) Old 11-18-2009, 01:29 PM
Banned by AutoGuide
ah, the plot thickens..
didn't know a Diablo was in play, what version of the CROM are you running..
yes I would try the stock tune and see if it behaves..
as I recall v9r12 is the latest revision for the diablo that 2005 - 2007 cars need, anything above that addresses 2008 and higher and isn't recommended for pre 2008 cars.
post #10 of 22 (permalink) Old 11-18-2009, 02:37 PM
Points: 68,105, Level: 1 Points: 68,105, Level: 1 Points: 68,105, Level: 1
UK CHRYSLER 300C's Avatar
Mr i,where dya get that info from,cos I checked every error number and that one states"no error code found" or summat like that,I need to know so I can find wierd errors for future reference and customers
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
ABS/BAS/ESP light wont go off on 2007 300 Limited slyjackson General Discussion 14 09-30-2015 12:10 PM
help esp bas abs light on sometimes red airbag light 808_300_regulah Problems / Dealer Service 14 04-27-2015 11:55 AM
ABS-BAS-Trac -control light yamabob Problems / Dealer Service 7 12-08-2009 04:20 PM
"abs, Eps/bas Lights Come On mikey's300c Problems / Dealer Service 2 06-07-2009 07:49 PM
Code P2112, ESP BAS, No throttle, Surging Idle srt42 1st Gen SRT8-Specific General Discussion 7 08-15-2008 07:36 AM
