Car Shut Down,, While Drving - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 24 (permalink) Old 11-25-2009, 08:00 PM Thread Starter
Points: 2,066, Level: 1 Points: 2,066, Level: 1 Points: 2,066, Level: 1
Car: 2005 chrysler 300c
I Was Drving To Work On The Freeway, I Was Going Like 75mph.....and Then Out Of No Where My Car Shut Down...all The Power Went Out...it Happend To Me 3 Times On The Way To Work......anyone Have A Idea What It Can Be...please Help........
mikey's300c is offline
post #2 of 24 (permalink) Old 11-25-2009, 09:51 PM
Elite Contributing Member
There are no TSB's or recalls for the LX's shutting off while driving. Chrysler has been silent on the problem. You are not alone. There are many other LX owners that have reported their cars shutting off while driving. A few forum members have reported bad spark plugs might be the cause. But there is no definitive solution.
joey is offline
post #3 of 24 (permalink) Old 11-25-2009, 10:02 PM
Points: 6,437, Level: 1 Points: 6,437, Level: 1 Points: 6,437, Level: 1
I doubt plugs would do it. Especially considering we have 2 per cylinder. I would be more likely to believe it's electrical. A bad computer, a short in the ignition that affects multiple coil packs (not likely) Could be a fuel pump or electrical issue going to the fuel pump. Could be a sensor starting to fail. I'd check for codes in the memory from when the car shut off. Thats at least a starting point. If you have a warranty take it to the dealer and tell them to run a star scan on it and see what they see..
S4-2-300C is offline
post #4 of 24 (permalink) Old 11-25-2009, 10:15 PM
I don't remember the exact reason, but the bad plugs were causing electrical issues, either from overheating or some sort of shorting. This caused the PCM to shut the car off.
joey is offline
post #5 of 24 (permalink) Old 11-25-2009, 10:32 PM
Here is the post from the Chargerforums I was trying to remember. Whether it really fixed the problem in the long run, I don't know.
Also, now reading it again, it looks like the poster may have been using non-stock plugs. So maybe this post is irrelevant.
Dodge Charger Forums - View Single Post - My Car Keeps Stalling!!!!!!!!!!!
Well Everyone, i got my car back last Friday! I wanted to make sure that it was fixed before i posted anything. It has been almost a week now and it is running great! I have been driving it pretty hard to make sure that it was not going to do the same thing! It took a tech. engineer to figure out that i had faulty plugs. The plugs were sending voltage back up through the coils and then to the PCM. It was then erasing all of the codes in the PCM. They kept my E3 plug to send them to Chrysler to see why it was doing this. So, any RT owners beware of putting any performance plugs in your cars. I was told that having 2 plugs and 2 coils per cylinder, that you do not need to run any plug that fires hotter.
Here are 2 lengthy threads on the stalling issue.
Charger just shuts off in gear while driving!! - Dodge Charger Forums
My Car Keeps Stalling!!!!!!!!!!! - Dodge Charger Forums
joey is offline
post #6 of 24 (permalink) Old 11-25-2009, 11:04 PM Thread Starter
well i havnt changed the plugs yet in my car.....i was doing to do a tuneup on it this weeks..... it was over heating on sunday but i fixed that problem.. but i also noticed that the light in the indash and inside light started to flicker like if they where going to burn out........i also have a air bag suspention on my car and when my car's compressor turn it sound like their not much juice going to them... i tested the battery and its gooo
post #7 of 24 (permalink) Old 12-02-2009, 02:34 AM
Points: 1,368, Level: 1 Points: 1,368, Level: 1 Points: 1,368, Level: 1
SHARKY's Avatar
Car: 2006 chrysler 300 C
I think it might be the dynamo (alternator) maybe it is not working well either you have to change the voltage regulator or you have to replace the whole thing.
SHARKY is offline
post #8 of 24 (permalink) Old 12-03-2009, 09:07 PM
Points: 21,921, Level: 1 Points: 21,921, Level: 1 Points: 21,921, Level: 1
slabhurta02's Avatar
Car: 2007 Chrysler 300
Got any updates? I'm curious to know. . .
slabhurta02 is offline
post #9 of 24 (permalink) Old 12-08-2009, 01:21 AM
Points: 6,428, Level: 1 Points: 6,428, Level: 1 Points: 6,428, Level: 1
clevername's Avatar
I need some updates too. This happened to me last night and again about 30min ago on the highway. scary stuff. The stereo's been popping lately, I don't know if that has anything to do with the problem but may be a clue.
clevername is offline
post #10 of 24 (permalink) Old 12-08-2009, 11:13 AM
clevername's Avatar
So it's looking like the first things to tackle are the plugs and TCM & PCM. This is what I'm gathering from other sites and links provided here.
Out of warranty how much will this run?
Any other suggestions?
This is really un-nerving since this is kind of the family car.
Car Won't Shut Off Normgarry Problems / Dealer Service 8 12-14-2010 12:13 PM
car shut off...??? shooter Problems / Dealer Service 1 02-24-2008 09:56 PM
Car wouldn't start and then it wouldn't shut off? bambam7171 Problems / Dealer Service 1 09-02-2007 04:24 PM
Car Just Shut Off urbanchemist General Discussion 11 06-06-2005 12:20 AM
Car shut down? Cruznit Problems / Dealer Service 2 01-14-2005 04:37 PM
