What do these trouble codes mean?? - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 03-10-2010, 01:26 PM   #1 (permalink)
Points: 6,015, Level: 1 Points: 6,015, Level: 1 Points: 6,015, Level: 1
Car: 300c chrysler 2006
Member Number: 17929
Can anyone tell me what these codes mean?
I had some ass*ole kick the side of my car and put a nice dent in it along with a lot of scratches. The airbag light came on shortly after he did this. I was driving down the street when he did this. I took the car to the dealership and these are the codes that came up. Can someone tell me what they mean, and would someone kicking the side of the car make the airbag light go on. I have side curtain airbags in my 300C.
b223d=OCM DTC Present
b1bbc=OCS Negative System Weight
ItalianBostonian is offline
Old 03-10-2010, 01:35 PM   #2 (permalink)
Points: 24,919, Level: 1 Points: 24,919, Level: 1 Points: 24,919, Level: 1
LSCto300C's Avatar
Car: 2007 Chrysler 300C in Steel Blue
Member Number: 16416
Where did he kick your car? More importantly, did you kill him on the spot or at least maim him in any way?
Try pulling fuse 11 for 30 seconds, that's always a safe place to start.
"When fascism comes to America, it will be wrapped in the flag and carrying a cross." - Sinclair Lewis
LSCto300C is offline
Old 03-10-2010, 11:41 PM   #3 (permalink)
Elite Contributing Member
Points: 56,038, Level: 1 Points: 56,038, Level: 1 Points: 56,038, Level: 1
Quiknen's Avatar
Car: 2005 Chrysler 300c AWD
Member Number: 20345
Send a message via AIM to Quiknen
Guess we're just living up to our names as Ma$$Holes lol
Good luck any pictures of your car... and that guys face after you beat him with a crowbar?
Real Name: Ian Butler
(Click above picture to see modifications)
Click here to see My Garage
5.7L Hemi Registry #1537 Quiknen
Quiknen is offline
Old 03-11-2010, 01:07 AM   #4 (permalink)
Member Number: 232
From the Service Manual.
B223D-OCCUPANT CLASSIFICATION MODULE DTC PRESENT
² When Monitored:
With the ignition on.
² Set Condition:
This DTC will set if the ORC receives a bus message with the active OCM DTC Present bit set.
Possible Causes
ACTIVE DTC IN OCCUPANT CLASSIFICATION MODULE OCCUPANT RESTRAINT CONTROLLER (ORC) Diagnostic
B1BBC-OCS NEGATIVE SYSTEM WEIGHT (CONTINUED)
² When Monitored:
While the CAN bus ignition status is in IGN_RUN, the module checks the sensor input ranges.
² Set Condition:
If the module detects a seat weight sensor input with the total seat weight below -6.5 kg +/- 1kg.
Possible Causes
DAMAGE TO THE PASSENGER SEAT STRUCTURE, RISER ASSEMBLY, CROSSMEMBERS, SEAT TRACKS, FLOOR PAN OBJECT UNDER SEAT OR REAR SEAT FOLDED DOWN AND RESTING AGAINST PASSENGER SEAT OCCUPANT CLASSIFICATION MODULE (OCM)
joey is offline
Old 03-11-2010, 11:38 AM   #5 (permalink)
I do have pictures. I would have loved to have beat the sh*t out of him, but he ran away.
Luckily there was a police officer on a detail and he helped me catch him. He is now being charged with a felony for the damage he did to my car.
So how do I fix this problem?
I always hear pull fuse 11. What does pulling fuse 11 do?
Old 03-11-2010, 01:11 PM   #6 (permalink)
Quiknen's Avatar
Fuse 11 just resets certain features in your computer... its good to do everyone once in a while
Quiknen is offline
Old 03-14-2010, 01:25 AM   #7 (permalink)
LSCto300C's Avatar
Haha that's awesome, a happy ending
I say screw it and let the dealer fix it at this *******'s expense.
Old 03-24-2010, 10:34 PM   #8 (permalink)
Points: 355, Level: 1 Points: 355, Level: 1 Points: 355, Level: 1
Car: 2005 chrysler 300c
Member Number: 26120
Hi everyone. I'm kind of new to this forum but, i have a problem with 300c. I have 2 trouble codes and i don't what they mean could someone please help. My MIL is on. The codes are 0406 & 0571.
calvin2000 is offline
Old 03-25-2010, 12:12 AM   #9 (permalink)
Points: 8,037, Level: 1 Points: 8,037, Level: 1 Points: 8,037, Level: 1
300fisch's Avatar
Car: 2006 & 2008 Chrysler 300C & 300C SRT8
Member Number: 23930
The 0406 is the EGR valve and 0571 is brake switch A circuit.
300fisch is offline
Old 03-25-2010, 03:15 AM   #10 (permalink)
Member Number: 232
P0406-EGR POSITION SENSOR CIRCUIT HIGH
When Monitored:
With the ignition on. Battery voltage greater than 10 volts.
Set Condition:
EGR position sensor signal is greater than 4.89. One trip Fault.
Possible Causes
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO (F856) 5-VOLT SUPPLY CIRCUIT
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT OPEN
(K900) SENSOR GROUND CIRCUIT OPEN
EGR SOLENOID ASSEMBLY
PCM
P0571-BRAKE SWITCH 1 PERFORMANCE
When Monitored:
Ignition on.
Set Condition:
If the output of Brake Switch No.1 to the PCM looks like it is not applied, while Brake Switch No.2 circuit isapplied the fault will mature in 60ms. One Trip Fault.
Possible Causes
(B15) BRAKE SWITCH NO.1 SIGNAL SHORTED TO GROUND
(B15) BRAKE SWITCH NO.1 SIGNAL OPEN
(B16) BRAKE SWITCH NO.2 SIGNAL SHORTED TO GROUND
(B16) BRAKE SWITCH NO.2 SIGNAL OPEN
(Z912) GROUND CIRCUIT OPEN
(F202) FUSED IGNITION SWITCH OUTPUT OPEN
STOP LAMP SWITCH
PCM
joey is offline
Diagnostic Trouble Codes List & How to Access Codes In EVIC jkspup2 Problems / Dealer Service 26 02-03-2012 07:28 PM
2 trouble codes....need help please! NVMYSRT8 SRT8-Specific General Discussion 13 06-20-2010 10:03 PM
Trouble Codes (HELP!) (Moved) Niko Problems / Dealer Service 11 12-17-2008 07:17 PM
Strange trouble codes and Light chevylover Problems / Dealer Service 5 03-29-2008 12:36 PM
Diagnostic trouble codes (DTC) HHPHEMI Performance General Discussion 2 01-08-2007 10:04 AM
