U0101 And Limp Home Omfg
Hey guys
I am not sure whats going on here..
I drove my 300 all day yesterday and this morning.
All was well, until I got in it later this moring with the family to go to breakfast.
The engine light came on and the ESP/BAS was on as well..
I check with with predator and I get a U0101 code... which I believe means there is an error witht he TCM and noting but that ccrappy star tool can diag it,
The car when you drive it is in limp home mode, less than 3k rpm and 35mph or under.. I have reset the stock tune, reinstalled the mod tune, changed the mod tune, plulled the giant fuse #11 in the rear trunk box (giant 12V 25Amp) I dont have a fuse in the front box where there is a slot #11 slot.
Still no help, I still have the same check engine light, ESP/BAS light and limp home.
I did pull the fuse #44 prior to these issues for the sun room, its not the first time i've done this, the sun roof stops working 60% of the time I use it.. and I just reset that fuse, its not burnt or nething, so that fuse is good.
About 2 weeks ago I was in a parking garage and it was hella dark plus my tint and the headlights usually come on, well they tried, the HID balasts kicked on light flickered they went out, and then all of the dash lights kicked on and off like flashed real quick, lights never came on with the auto function, I had to manually do them, but they have worked on AUTO right after that no issues. I also tried to use the tranny reset command in t predator, says operation failed. and when I clear the trouble codes, it come right back immediatly.
What is going on? I had my tranny serviced the last time the predator flashed that code at my dealership they raped my ass for $700, I cnalt afford that again, and thats the only place that can read tranny codes.
What do I do?
Thanks guys
-Louis
