POLL: Does your LX (Hemi or otherwise) Stall while driving? - Chrysler 300C Forum: 300C & SRT8 Forums
View Poll Results: Does your LX (Hemi or otherwise) stall/shut-off while driving!?
Nope, never. Runs like a top. 62 60.78%
YES! Under sharp turns with the brake applied 5 4.90%
YES! Under sharp turns while feathering the throttle 3 2.94%
YES! All the time, no matter what! 9 8.82%
YES! In stop-and-go driving 26 25.49%
YES! But only with the AC on, plus one of the above conditions (specify) 7 6.86%
YES! With the AC on, it stalls all the time 1 0.98%
Multiple Choice Poll. Voters: 102. You may not vote on this poll
post #1 of 304 (permalink) Old 10-03-2005, 10:02 AM Thread Starter
Points: 7,944, Level: 1 Points: 7,944, Level: 1 Points: 7,944, Level: 1
toothdoc's Avatar
Car: 2005 mag 300c
car stalls after fill up gas tank
my 05 300c 25k miles, has been stalling after I fill up gas tank. when I get to first stop light after fill up it wont idle, i have to grind on starter. It has left me stranded in intersection. it does not happen every time and by the time i get to dealer its fine?? dosent matter which brand. this has been happening for 3 months now. any body else? any tsb"s . only thing i can think of is something floating to top of fuel tanks and cloging pick up??
toothdoc is offline
post #2 of 304 (permalink) Old 10-03-2005, 10:11 AM
ADMIMISTRATOR
Points: 299,130, Level: 1 Points: 299,130, Level: 1 Points: 299,130, Level: 1
Northern Rider's Avatar
Make certain the gas cap is fully secured. Otherwise the engine will cut out.
Patrick ... Latest List of Road Racing Mods ..........
2015 Charger Hellcat is in the stable!
Northern Rider is offline
post #3 of 304 (permalink) Old 10-03-2005, 10:12 AM
Elite Contributing Member
Points: 62,895, Level: 1 Points: 62,895, Level: 1 Points: 62,895, Level: 1
well that didnt happen to me when filing up, but it happened to me when i cam to a stop and my car just stalled.
There are posts about it all over here.
When i went to the dealer and told them my car stalled, he said he changed a pin and it hasnt happen yet, its been about 2 weeks so far.
NautcaSprt6 is offline
post #4 of 304 (permalink) Old 10-03-2005, 04:45 PM Thread Starter
toothdoc's Avatar
Car: 2005 mag 300c
what kind of pin?
thanks
toothdoc is offline
post #5 of 304 (permalink) Old 10-03-2005, 04:59 PM
Points: 42,897, Level: 1 Points: 42,897, Level: 1 Points: 42,897, Level: 1
Meister's Avatar
Concur.
Dealer recommendation from 2 different dealers is go 5 to 7 clicks past where it feels snug--it's critical that the cap be very tightly secured.
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
Meister is offline
post #6 of 304 (permalink) Old 10-03-2005, 05:23 PM
Points: 3,677, Level: 1 Points: 3,677, Level: 1 Points: 3,677, Level: 1
charlie D's Avatar
Car: 2006 Chrysler 300C-AWD
I have to concur with NR. Even if there is no apparent indication, replace the gas cap.It may possibly be flawed and with time simply doesn't seat properly.
2006 300C AWD
C V loaded
Molded mud flaps Mopar window shields E&G Classic double weave grill & inserts Windowstinted 35% Custom Exhaust
Padded leather console cover
Winged Chrysler visor graphics
Winged Chrysler floor mats
S/S Trunklid molding
Custom paint matched:Taillight Bezels,Engine shroud,Air box lid,SRT8 lip & roof spoilers
Zinik Z17's/BFG KDW 2's/255/55VR18/RF
Body Kit - still in box
charlie D is offline
post #7 of 304 (permalink) Old 10-03-2005, 06:08 PM
Meister's Avatar
Funky lends a hand
Toothdoc, one of our sister forums is blessed to have a very knowledgeable, helpful, Dodge tech in residence. I took the liberty of running your problem past FNKYCHKN and here's his response:
"...i would suspect a leaky duty cycle purge solenoid. as fuel is pumped into the tank, the vapors from the tank are pushed into the canister, to be burned as part of fuel mixture during a normal drive cycle. the PCM cycles the purge solenoid valve to allow vapors from the canister to be introduced into intake manifold. if this valve is leaking, the amount of vapors cannot be properly regulated and may result in an overly rich condition which could cause idle undershoot and stalling.
another thing that could affect mixture is the canister being saturated (usually caused by overfilling tank).
TSB 18-031-04A deals with rough idle after hot restart.
good luck."
This doesn't mean that you don't have to keep your fuel cap super tight, BTW.
Meister is offline
post #8 of 304 (permalink) Old 10-03-2005, 07:04 PM
what kind of pin?
thanks
I dno,
The guy told me that they installed a pin, but i dont know what or where it goes.
post #9 of 304 (permalink) Old 10-04-2005, 11:57 AM
Points: 2,502, Level: 1 Points: 2,502, Level: 1 Points: 2,502, Level: 1
mspeasl's Avatar
Originally Posted by Meister
Toothdoc, another thing that could affect mixture is the canister being saturated (usually caused by overfilling tank). TSB 18-031-04A deals with rough idle after hot restart. good luck."
Gang,
Most new car tech's will tell you to STOP filling your tank when the automatic hose shuts off on its own. Your (our) continuing to fill after that does just what is stated above. That's bad. One thing that they have also told me is to fill on SLOW instead of fast and air will leave the tank and not leave air pockets causing the pump to shut off early.
Mspeasl
05 300 'C' Satin Jade Pearl
Delivered June 1, 2004
08 'X-Runner' Radiant Red 6sp
Delivered November 15, 2007
09 370 'Z' Solid Red Touring 6sp
Delivered April 7, 2009
mspeasl is offline
post #10 of 304 (permalink) Old 10-04-2005, 12:04 PM
Meister's Avatar
Originally Posted by mspeasl
Gang,
Excellent, practical, everyday usage, application of Funky's comments, mpeasl, thanks.
Meister is offline
EXPIRED: F/S: STALL CONVERTOR-Precision Industries 3200 Stall with 3rd clutch pack Jected Parts Buy/Sell Forum 2 09-21-2009 06:41 PM
EXPIRED: F/S: STALL CONVERTOR-Precision Industries 3200 Stall with 3rd clutch pack Jected Parts Buy/Sell Forum 5 06-12-2009 03:33 PM
Thinking Of Driving My 09 300c HEMI From Colorado To Mexico, Belize & Guatemala???? Deepwaterblue300c General Discussion 3 10-19-2008 09:56 PM
Stall Converter? Hemi6.1 1st Gen SRT8-Specific Performance & Engine/Intake/Exhaust Mods 9 01-11-2007 09:22 PM
Gear + stall Gloveperson Performance General Discussion 6 02-27-2005 05:51 PM
