Need some help - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
SRT8-Specific General Discussion General Discussion specific to the SRT8 models. If your topic is not specific to the SRT8, please post it in the All Models Forums.
Old 12-22-2012, 06:31 PM   #1 (permalink)
Points: 927, Level: 1 Points: 927, Level: 1 Points: 927, Level: 1
arnold1989's Avatar
Car: 2006 chrysler 300c srt8
Member Number: 38583
Need some help
I have a 2006 srt8 96k miles have intake and exhaust other then that stock. iv had a few people tell me the motor sounds like it has a mis. it dose idle kinda hard at times but nothing to bad. iv also had some say that its just the hemi motor so just want to have some input
Sent from my DROID RAZR using AutoGuide.Com Free App
arnold1989 is offline
Old 12-22-2012, 10:15 PM   #2 (permalink)
Points: 29,042, Level: 1 Points: 29,042, Level: 1 Points: 29,042, Level: 1
MADDOG's Avatar
Member Number: 11602
At what RPM does it idle? Have you cleaned your throttle body lately? Any codes showing?
Michael
MADDOG is offline
Old 12-22-2012, 10:55 PM   #3 (permalink)
Points: 20,421, Level: 1 Points: 20,421, Level: 1 Points: 20,421, Level: 1
Sodak's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 24540
When's the last time plugs were changed?
See My Garage
http://www.300cforums.com/forums/garage/1129
SRT A Factory Hotrod
Sodak is offline
Old 12-22-2012, 10:58 PM   #4 (permalink)
arnold1989's Avatar
No codes and it idles realy low not sure how low for sure tho and i have no records of the maintenance done to the car befor i got it how often should the plugs be changed out
Old 12-22-2012, 11:49 PM   #5 (permalink)
Points: 52,208, Level: 1 Points: 52,208, Level: 1 Points: 52,208, Level: 1
Activity: 82% Activity: 82% Activity: 82%
Fisch's Avatar
Member Number: 22401
First things first, clean your throttle body. That's the cheapest and easiest thing to do, and you can have some surprising results - especially when experiencing bad idling issues.
It's simple. First buy some throttle body cleaner - few bucks at any auto store. Remove your intake arm and you'll be staring at your TB on the front of the manifold. Remove the plug on the TB and remove 3 or 4 bolts that are holding it to the manifold. Then just clean her up with the TB cleaner and replace.
If it hasn't been cleaned in nearly 100K miles, you probably have quite a bit of gunk on it - possibly causing the butterfly not to close properly or stick a bit... hence, idle issues.
Fisch is offline
Old 12-22-2012, 11:54 PM   #6 (permalink)
arnold1989's Avatar
Im all for starting with the cheep and ez parts first so ill do that and hope everything works it self out thanks alot guys
Old 12-23-2012, 12:07 AM   #7 (permalink)
Fisch's Avatar
Happy to help.
Here's the TB cleaner I use... And my TB before and after cleaning - think these pics were probably from around 50K miles or so...
Don't know if this will be your complete solution, but if you are approaching 100K miles then it certainly can't hurt to clean it anyways!!
Fisch is offline
Old 12-31-2012, 12:50 PM   #8 (permalink)
Points: 5,703, Level: 1 Points: 5,703, Level: 1 Points: 5,703, Level: 1
Activity: 29% Activity: 29% Activity: 29%
MY SRT8 HEMI's Avatar
Member Number: 10129
Do you need a new gasket when doing this?
2006 BB 300C SRT8., k&n cold intake,BT oil catch, bilstein shocks all around, dc sport top carbon steel strut tower bar, challanger motor mounts., alpine touch screen, rear spoiler.Custom exhaust suitcase removed...magnaflow resonators 4 inch tips,91 CAI with an In-tune...
Gone ..2006 Dodge Magnum SRT-8
MY SRT8 HEMI is offline
Old 12-31-2012, 01:15 PM   #9 (permalink)
BIG OLE DOG
Points: 187,187, Level: 1 Points: 187,187, Level: 1 Points: 187,187, Level: 1
Activity: 57% Activity: 57% Activity: 57%
Northern Rider's Avatar
Member Number: 538
Plugs on the SRT8 are scheduled for every 100,000 miles. I changed mine at around 70 k and they needed changing!
Remember - there are 16 of them and you must use the specified plug.
- Patrick -............ Latest List of Road Racing Mods ..........
"Life is not measured by the number of breaths we take,
but by the moments that take our breath away” .
Northern Rider is offline
Old 12-31-2012, 01:16 PM   #10 (permalink)
MADDOG's Avatar
Normally you do as the old one won't come off clean for re-use.
MADDOG is offline
MY SRT8 HEMI (12-31-2012)
