Originally Posted by Sodak
My question is why would you wan't this feature...Might as well leave it in drive then.
LOL...it just keeps ya from bumping the rev limiter if ya forget to manually shift.
For the op, I have my shift points set where the car makes the most HP. Anything above that is a waste as HP starts to drop off and you wanna keep it square in the power band.
And yes, the car will have more power in 1, 2 or 3 as you are running a higher RPM. Look at it this way...at 25 mph in first gear you are running a lot higher RPM than 25 mph in 4th gear.
