Old 01-25-2006, 12:19 PM   #1 (permalink)
HealeyRick's Avatar
Car: 2006 BFHemi CSRT-8
Member Number: 945
Location: If you don't have a need to know, you don't need to know.
Report of Rhino Ramp Failure
Got this report of a Rhino Ramp failure from another forum I'm on:
http://www.tamparacing.com/forums/ge...to-pieces.html
I know we've had posts from SRT-8 owners using these in order to avoid using a jack to do an oil change. Assuming the report's legit, I'd be very nervous about using a ramp to hold up one of our beasts when a lightweight import made it collapse.
Rick
HealeyRick is offline
Old 01-25-2006, 01:56 PM   #2 (permalink)
qictrk's Avatar
Car: 2006 SRT8 SRT8
Member Number: 1429
The old ones are probably still good. Now, in order to save a couple of pennys, they are probably made in China or Mexico. Scary stuff. Cecil................
Black SRT8
Giovanna Wheels
Precision Grille
Painted engine parts(good for 10hp)
GSM switches
Other little touches here and there
Pictures at my web site http://community.webshots.com/user/qictrk
qictrk is offline
Old 01-25-2006, 02:11 PM   #3 (permalink)
JustForFun's Avatar
Member Number: 1361
Darn...I have these at home. I will definately have to check mine out. Thanks for the heads up on this!!!
JFF
JustForFun is offline
Old 01-25-2006, 02:52 PM   #4 (permalink)
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
Excellent thread. Scary stuff. I posted more than a year ago to have a back up in place. Never trust any single device when crawling under a car. I use the ramp and weight load my hydraulic jack at the subframe on the side I work on and I locate a jack stand on the other side. Set the park brake and chock the rear wheels.
II kings 9:20 is offline
Old 01-25-2006, 03:09 PM   #5 (permalink)
Member Number: 1456
I've got a set of Rhino Ramps (the heavy-duty gray ones) and have never had the slightest indication of a problem with them. I've never heard of another failure, though it's possible that it's happened.
Personally, I'm also a belt and suspenders kind of guy when I've got a ton or two suspended above me--I always toss the jackstands under the car . . . just in case.
One of the first things that came to my mind, though, was the possibility that the guy drove past the end, and the ramp broke when his car came crashing down on it. It's a possibility that's raised in that thread.
Thanks for the "heads up." While my faith in Rhino Ramps isn't yet shattered, it's a good reminder to have some redundancy in your safety planning, particularly when it's potentially a matter of life and death.
MikeB is offline
Old 01-25-2006, 04:05 PM   #6 (permalink)
BrilliantBlackHemi's Avatar
Member Number: 104
12,000 lbs rated each. Strange someone had a problem. I have not.
Robert
2006 Brilliant Black Crystal 300C SRT8
1999 Bright Platinum Metallic 300M PHP
BrilliantBlackHemi is offline
Old 01-25-2006, 07:41 PM   #7 (permalink)
70GT6's Avatar
Car: 2006 SRT8 Magnum
Member Number: 2986
Suspicious - look where both ramps broke...off to one side and on the end. Looks like maybe it was a drive over and the rockers landed on the ramps.
Maybe not... but it looks odd that both ramps have the same damage and the driver states that "one" broke when his foot slipped off the clutch...look like both broke this way.
Go Team Magnum
70GT6 is offline
