Old 03-05-2006, 12:51 AM   #1 (permalink)
Car: 2006 300C SRT8 - Black
Member Number: 4150
Engine wont start
After driving home from work last night, I parked my '06 SRT8 in my driveway for about 20 minutes. I came back out to drive, attempted to start the car and the tach just spun like crazy while the engine would crank over but not start. At first I thought it may be an electrical issue but I've confirmed that its not the battery and its not a fuel issue. Again the engine turns over just fine but it won't start. The car has 7000 city miles (los angeles). Could this be a software problem? I recently discovered the EVIC displays. It is possible that something was changed in the software and now the engine wont start?
BTW, be aware that when you call DCX roadside service, they do not send flat-bed trucks. Watching an old tow truck pinching those beautiful wheels is extremely painful.
ERSnLA is offline
Old 03-05-2006, 07:51 AM   #2 (permalink)
IGOTTASRT8's Avatar
Member Number: 2287
Not sure what the issue is but are you the guy I met at the car wash on Sepulveda?
NX Nitrous Kit With Maximizer 2
Diablo Predator Tuner
GSM Track Mod
Mopar CAI
Zoomers Exhaust
Stant 170 Thermostat
12.2 @ 116 1.99 60ft Famoso Dragstrip
IGOTTASRT8 is online now
Old 03-05-2006, 11:30 AM   #3 (permalink)
Buz-CCC's Avatar
Car: 2008 Chrysler 300C
Member Number: 3268
Just a thought try your other key and see if car starts.
Ed,
2008 Silver l 300C/Dk Slate Int.Everything except rear VES! Del 8/26/08
Mods Slate Slush Mats/Mopar Molded Splash Guards
SS Pillar Trim/SS Trunk Lid Trim
Led's all Int. Ext. Flasher Stop 20 led towers in tail Backup 50 watts (Bright)
24oz Slate Mats (Hemi) DRL's Enabled
Buz-CCC is offline
Old 03-05-2006, 02:10 PM   #4 (permalink)
moddog's Avatar
Member Number: 1965
Dose it try to start then doesn't that happen to me . The anti-theft system failed an I could not start my car. This was last year and it took the dealer a weak to get the part in and fix it.
moddog is offline
Old 03-05-2006, 02:44 PM   #5 (permalink)
Member Number: 4150
The one and only. Hope your doing well and your car is still nice and clean. Regards,
ERSnLA is offline
Old 03-05-2006, 05:06 PM   #6 (permalink)
CJR300C's Avatar
Car: 2006 Loaded 300C SRT 8
Member Number: 4297
Send a message via Yahoo to CJR300C
I had the same problem, the car only had 110 miles on the car. I tried both keys but the car would only start for 2 or 3 seconds. I had the dealer come and pick the car up. I don't know what they did, but they kept it overnight. I have had the problem again. But I do have another problem. Sometimes when I go to start the car, it'll yurn over for a few seconds then start. I barely have 6k on the car.
CJR300C is offline
Old 03-05-2006, 10:41 PM   #7 (permalink)
Voice of Reason's Avatar
Car: 2006 SRT8 Magnum
Member Number: 3906
When that problem happened, did the remotes quit working also, and did the little red "dot" (anti-theft) light stay on steadily (near the fuel gauge)??
Voice of Reason is offline
Old 03-05-2006, 11:44 PM   #8 (permalink)
CJR300C's Avatar
Member Number: 4297
The light did stay on. The dealer couldn't understand it at first. I think they may have re-flashed the car and the keys.
CJR300C is offline
Old 03-05-2006, 11:50 PM   #9 (permalink)
Member Number: 3906
Interesting that this seems to not just happen to me. Try this...
Next time it happens (if, I guess) go into the rear power center and pull fuse #14, then start the car. I found this by educated guess and a little trial and error (I thoroughly believe that there is always a "back door" for servicing purposes, and in this case I was right.) Mine started right up--and *stayed* running, red light went out, remotes worked. I popped the fuse back in while it was running, and haven't had the problem since. Good luck...
trent...
Old 03-06-2006, 04:09 AM   #10 (permalink)
charlie D's Avatar
Car: 2006 Chrysler 300C-AWD
Member Number: 2420
Fuse 14
trent...
Trent,
Very helpful post --Thanks from all !!!!!!
2006 300C AWD
C V loaded
Molded mud flaps Mopar window shields E&G Classic double weave grill & inserts Windowstinted 35% Custom Exhaust
Padded leather console cover
Winged Chrysler visor graphics
Winged Chrysler floor mats
S/S Trunklid molding
Custom paint matched:Taillight Bezels,Engine shroud,Air box lid,SRT8 lip & roof spoilers
Zinik Z17's/BFG KDW 2's/255/55VR18/RF
Body Kit - still in box
charlie D is offline
