Originally Posted by slimmbones
What is load equalizers and can you buy them at kragen? Then what would be a option for reverse i painted my lights brillant silver?
A load equalizer is an electronics gizmo like a ballast its basically a black box that you have to wire into the turn signal circuit if you use LED bulbs for your turn signals (that's why I didn't use LEDs for the turn signals). You can get it from autolumination.com who also sells the LED bulbs.
For reverse, I like the halogen reverse lights that I mentioned earlier from PepBoys. They're either 50 or 55 Watt and plug right into the stock fitting and they're brighter than stock.
