» Sponsor Links
»Garage Storage and Cabinets
Old 03-15-2007, 09:24 AM   #1 (permalink)
Points: 1,817, Level: 1 Points: 1,817, Level: 1 Points: 1,817, Level: 1
kcshaner's Avatar
Car: 06 Chrysler 300 SRT-8
Member Number: 11142
My fan has never turned on....
Temps have gotten as hi as 222...maybe 224 and my fans have never kicked on. Is this normal? Anything I should check?
Also, my temp needle usually sits a shade above or right at the 200 mark, but the digital readout can be from 180-220 and there will be no change in where the needle sits. Which is more accurate?
Thanks.
2006 300 SRT-8 Black on black with all options
E&G Classic grill
Mopar CAI
Magnaflow catback
Magnaflow hi-flow cats
176 degree thermostat
kcshaner is offline
Old 03-15-2007, 09:52 AM   #2 (permalink)
Points: 14,723, Level: 1 Points: 14,723, Level: 1 Points: 14,723, Level: 1
Car: 2005 Chrysler 300C SRT-8
Member Number: 1431
Remember - there are two different temps. Oil temp, and coolant temp. Oil temp will run high, and is seen in the normal digital guage as you page through. Coolant temp is found in the EVIC screens. That temp should run up to about 216 before the fans turn on. Oil temp will easily run in the 230's.
So far there are no issues with overheating. The reported numbers seem to alarm a number of people, but you are fine.
JMatt is offline
Old 03-15-2007, 10:15 AM   #3 (permalink)
kcshaner's Avatar
I thought when you went through the digital stuff on the dash it was oil pressure, then water temp....is that not right? I didn't think there was an oil temp
Also, I have not installed the thermostat yet....hopefully today.
E&G Classic grill
Mopar CAI
Magnaflow catback
kcshaner is offline
Old 03-15-2007, 11:59 AM   #4 (permalink)
Member Number: 1431
Oil pressure, then oil temp. Water temp is in evic mode.
JMatt is offline
Old 03-15-2007, 01:09 PM   #5 (permalink)
kcshaner's Avatar
I feel like an idiot...after I typed this I checked while driving the car and it is definitely oil temp that I was thinking was water temp.
Can you explain the evic mode or how to see your water temp?
Thanks!
E&G Classic grill
Mopar CAI
Magnaflow catback
kcshaner is offline
Old 03-15-2007, 01:19 PM   #6 (permalink)
Points: 7,384, Level: 1 Points: 7,384, Level: 1 Points: 7,384, Level: 1
stealthsrt8's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 7491
these links might help.
Access EVIC Data & Diagnostic Trouble Codes
New EVIC Easter Egg??
Last edited by stealthsrt8 : 03-15-2007 at 01:20 PM. Reason: reordered links to threads
stealthsrt8 is offline
Old 03-15-2007, 01:57 PM   #7 (permalink)
Points: 8,677, Level: 1 Points: 8,677, Level: 1 Points: 8,677, Level: 1
NYC_SRT8's Avatar
Member Number: 5993
Trader Rating: (16)
Thanks!
Srt8 beginnger's mistakes ...lol. I was once there . So it turns out you really have a 180 t-stat...
Best - 12.1 @115.15 1.89 60ft
NYC_SRT8 is offline
Old 03-15-2007, 02:31 PM   #8 (permalink)
kcshaner's Avatar
Originally Posted by stealthsrt8 View Post
Nice....I can't wait to use this feature
E&G Classic grill
Mopar CAI
Magnaflow catback
kcshaner is offline
Old 03-15-2007, 02:33 PM   #9 (permalink)
kcshaner's Avatar
Actually, no...it was a 203 degree stat I just took out. The car ran MUCH cooler till I sat in line at a drive through....then it got hotter than it ever has Is it possible there is an air bubble or something
I sent you a PM
E&G Classic grill
Mopar CAI
Magnaflow catback
kcshaner is offline
