Ok, Thanks a ton moose, I really appreciate your advice and input!
-Fionn
PS. how long does each 10lb bottle last you? N20 is about $3lb right? What wide band o2 gauge do you suggest? I was thinking about the MSD Dash Hawk, it supposedly has a wide band o2 sensor hookup, wide band o2 sensors are about $80-100, Dash Hawk is $300. Other route is a simple wide band o2 gauge, those seem to be around $320 with wide band o2 sensor.
thanks again!
Originally Posted by Moose
I'm not real famy with the Zex progressive kit. At the track I don't really have any traction issues (when nos kicks on), just on the street. I guess the progressive would be fine, I just know it works without it.
As far as undue stress, I have not had any problems and I have gone through many many many bottles. I don't even have as much as a dash rattle. I also do a very fine inspection on my vehicle before and after I run at the track. Now if you go 150 shot with DR's you are playing with your half shaft life.
I'd just like to see nos as an additive to your hp, not the source of your hp. I'm going to be looking to augment my NA here soon, too.
Sounds like you know your stuff pretty well and are doing some good pre planning. I think you'll be just fine.
