» Sponsor Links
»Garage Storage and Cabinets
Old 04-21-2007, 10:19 PM   #1 (permalink)
Points: 3,665, Level: 1 Points: 3,665, Level: 1 Points: 3,665, Level: 1
05Silver_C's Avatar
Member Number: 8630
SRT valve caps!!!!!
Found these and figured some of you SRT guys might like
Camisasca SRT Logo Valve Stem Caps - AutoTruckToys.com
Pioneer AVIC-Z1 w/ Ipod and Bluetooth adapters
Custom Nav bezel
60GB Ipod
JL 1000/1
JL 13W7
Kinetik HC 2400
AAC Halos w/ Paint matched housings
Silverstar ultras High/Low/Fogs
Viper 791xv
300C Plate Frames
Front plate lowered
HEMI C valve caps
Borla 140125 5in Tips
TIS 02 (20 inch) w/custom BT Center Cap Emblems
Avon Tec 550s
TZ Grill w/ custom BT Emblem
05Silver_C is offline
Old 04-21-2007, 10:32 PM   #2 (permalink)
srt8danno's Avatar
Member Number: 1971
One of our supporting vendors also has those….thanks for the information.
http://www.300cforums.com/forums/ext...ght=valve+caps
srt8danno is offline
Old 04-21-2007, 11:14 PM   #3 (permalink)
Points: 2,081, Level: 1 Points: 2,081, Level: 1 Points: 2,081, Level: 1
SRT-8 Hemi's Avatar
Car: 2007 Chrysler 300C SRT-8
Member Number: 11569
great find!
SRT-8 Hemi
SRT-8 Hemi is offline
Old 04-22-2007, 02:38 AM   #4 (permalink)
Points: 2,585, Level: 1 Points: 2,585, Level: 1 Points: 2,585, Level: 1
Car: 2006 Chrysler 300C SRT8 Brilliant Black
Member Number: 5534
Make sure they are plastic! I had a valve stem problem two months ago. In November I had two new tires put on the SRT8 on the back, had them rotated to the front, in Feb. the mechanic wanted to check the air pressure and in the process of getting the valve cap off broke he broke off the valve stem unit which is attached to the pressure sensor. The valve stem and pressure sensor are made of alumimim (?: whatever!) and the cap was steel, some one had put a steel cap on instead of the stock plastic one, the cap and valve stem welded together! only took 3 1/2 months. just make sure the cap is made out of plastic.
Lucky is offline
Old 04-22-2007, 09:15 AM   #5 (permalink)
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
Seweet!!!!
DUBSTER is offline
Old 04-22-2007, 05:53 PM   #6 (permalink)
sjz
Points: 6,288, Level: 1 Points: 6,288, Level: 1 Points: 6,288, Level: 1
sjz's Avatar
Car: 2006 SRT8 300C
Member Number: 964
I gave away a set of them....They are stainless steel so they can't rust, so no issues there.
The problem isn't rust, it's galvanic action generated corrosion, caused by the contact of two dissimilar metals (i.e. aluminum & steel, or even stainless steel). Maybe a TINY bit of never - seize compound on the male threads would help. The valve stems are a little more fragile than what we're used to.
-Steve
Brilliant Black
Goodyear AS, Sunroof
Groups I & II, Kicker
Built: 7/1/05 at 7AM
Mopar CAI
Jeep OEM underhood light
TCM flash TSB #: 21-020-06
____________________________
1967 International Scout 800
345 cid V8
---- The FIRST SUV----
sjz is offline
Old 04-22-2007, 06:06 PM   #7 (permalink)
Points: 12,324, Level: 1 Points: 12,324, Level: 1 Points: 12,324, Level: 1
CplDaugherty's Avatar
Member Number: 5668
I have the stealth auto 300C caps, I've seen the SRT ones in person as well. I always take mine off and shine them when I clean my rims, good info on them siezing up though.
CplDaugherty is offline
Old 04-22-2007, 06:44 PM   #8 (permalink)
Points: 19,747, Level: 1 Points: 19,747, Level: 1 Points: 19,747, Level: 1
Activity: 32% Activity: 32% Activity: 32%
GoofyTimL's Avatar
Member Number: 3755
I've had the Stealth Auto 300C caps on the H.E. for some time now and no such problems. Added their SRT8 caps to the MSRT8 within the first month.
Will keep on eye on them however. The issue with dissimilar metals is worth considering.
GoofyTimL is online now
Old 04-25-2007, 08:40 AM   #9 (permalink)
05Silver_C's Avatar
Member Number: 8630
Ive had the 300C caps that came with my plate frames om the stock 18s for 6+ months with no problems, also have em on the 20s. I dont have tire pressure monitors, so I check pressure on a normal basis
Custom Nav bezel
60GB Ipod
JL 1000/1
JL 13W7
Kinetik HC 2400
Viper 791xv
300C Plate Frames
Front plate lowered
HEMI C valve caps
Avon Tec 550s
Old 04-25-2007, 11:05 AM   #10 (permalink)
Member Number: 5534
-Steve
Thanks for clearing up this point for me. I did not know what happened exactly, just that it cost me one sensor unit, but under warranty.
Lucky is offline
