Headlights flickering - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
SRT8-Specific General Discussion General Discussion specific to the SRT8 models. If your topic is not specific to the SRT8, please post it in the All Models Forums.
Old 03-05-2012, 08:51 AM   #1 (permalink)
Points: 843, Level: 1 Points: 843, Level: 1 Points: 843, Level: 1
Car: 2007 Chrysler 300C SRT8
Member Number: 33815
Hi Everyone:
I have an 07 300C SRT8 6.1 and recently I noticed that my headlights will flicker on and off randomly.
I took it to 2 dealerships to have it looked at and both say they cannot duplicate the problem and don't do anything about it.
It is starting to drive me crazy and it can be dangerous when going 75 on a highway and both headlights flicker off.
Anyone know about this issue or have any ideas?
Thanks a million!!
Maaeini is offline
Old 03-06-2012, 12:29 PM   #2 (permalink)
Points: 13,234, Level: 1 Points: 13,234, Level: 1 Points: 13,234, Level: 1
Jetblak6.1's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 23888
Do you have factory HID's? If so i would think maybe you have a bad ballast. Otherwise jack the front end up and look for a loose connection, at least thats where id start. Or look for a loose fuse in the fuse block that deals with the headlights etc. See what that does.
Arrington cai, BBK90mm, OBX LT's, SLP loudmouth full system, Magnacharger TVS2300 @ 6psi, SRTmax cam, 180 Tstat, phenolic spacers, Johan tune, Mickey Thompson ET's 305/45/18, NGK TR-6 7.8@92 - 12.1@116
Jetblak6.1 is offline
Old 01-29-2013, 12:54 PM   #3 (permalink)
Points: 33, Level: 1 Points: 33, Level: 1 Points: 33, Level: 1
Member Number: 42931
Headlight flickering
Has the headlight flickering problem ever been resolved? I've taken my car to the dealer 3 times - paid over $800 - and still have the problem. they tell me they "just have to keep changing out parts" until they figure out what is wrong. My car is an '06 so there is no warranty. the computer has been re-programmed 3 times now, at $150 each time. I need HELP!
NoMoreChryslers is offline
Old 01-29-2013, 01:03 PM   #4 (permalink)
Resolved
Yes. After checking ballasts and connections I finally decided to just change both HID bulbs and the problem stopped. Apparently when the D1S HID bulbs get to end of life they start to flicker on and off. Ever since I changed the bulbs I have not had any issues. Hope this helps.
Maaeini is offline
Old 01-29-2013, 01:09 PM   #5 (permalink)
Thanks!
Thanks for the reply. I suppose I'll try that next. I won't be a happy camper if I've spent all this money changing modules, etc and getting it reprogrammed if it turns out to be just the headlights. But I will be thankful to be able to drive at night again!
Old 01-29-2013, 01:21 PM   #6 (permalink)
BTW, what type of bulbs did you purchase? Online or at a local store?
Thanks!
Old 01-29-2013, 01:36 PM   #7 (permalink)
Headlights
Oh I definitely feel you. I went through all the same issues and reprogramming for months until I finally replaced the bulbs and it fixed it. I was pretty upset about it lol. I just purchased the OEM bulbs from a local store. For my '07 it was Sylvania D1S HID bulbs. I would double check your manual and make sure to find the right bulb because it could be either a D1S, D2S or D4S. I'm pretty sure tho if you have a 06 300 with factory HIDs then it should be the D1S. Good luck!
Maaeini is offline
Old 01-29-2013, 01:54 PM   #8 (permalink)
Chrysler Customer Service Agent
Points: 1,509, Level: 1 Points: 1,509, Level: 1 Points: 1,509, Level: 1
ChryslerCares's Avatar
Car: 2013 Chrysler 300C
Member Number: 33558
The '06 is a DS1 HID Bulb. Below is a list of all the exterior lamp bulbs for the 06 Chrysler 300
2006 MODEL REPLACEMENT LIGHT BULBS - EXTERIOR
LIGHT BULBS — Exterior (300, 300 Touring Models) -- Bulb Number
Low Beam Headlamp -- 9006
High Beam Headlamp -- 9005
Front Park/Turn Lamp -- 3757AK
Front Inner Park Lamp -- 194NA
Front Outer Park Lamp -- 194NA
Front Fog Lamp—If Equipped -- 9145/H10 (Serviced at Dealer)
Front Sidemarker -- W5W (Serviced at Dealer)
Tail/Stop/Turn Lamp -- 3057
Rear Sidemarker -- 168
Backup Lamp -- 3057
Center High Mount Stop Lamp (CHMSL) -- LED
License -- 168
LIGHT BULBS — Exterior (300C Models) -- Bulb Number
Low Beam Headlamp (Standard Halogen) -- 9006XS
Low Beam Headlamp – High Intensity Discharge (HID) -- D1S (Serviced at Dealer)
Front Park/Turn Lamp -- 3157AK
Front Fog Lamp -- 9145/H10 (Serviced at Dealer)
Tail/Stop Lamp -- 3057
Tail Lamp -- 3057
Turn Signal Lamp -- 3057
Backup Lamp -- 3057
License -- W5W
ChryslerCares is offline
Old 01-29-2013, 08:32 PM   #9 (permalink)
Points: 8,177, Level: 1 Points: 8,177, Level: 1 Points: 8,177, Level: 1
Activity: 88% Activity: 88% Activity: 88%
therealfleen's Avatar
Member Number: 40424
Backup Lamp -- 3057
License -- 168
Tail Lamp -- 3057
Backup Lamp -- 3057
License -- W5W
Are these the same for 05s?
Sent from AutoGuide.com App
05 300c AWD
AEF Stage II CAI
Predator 93 Oct Tune
Billet Catch Can
170 T Stat
LEDs all around
Custom Audio Build
therealfleen is online now
Old 01-29-2013, 08:35 PM   #10 (permalink)
Points: 30,445, Level: 1 Points: 30,445, Level: 1 Points: 30,445, Level: 1
MADDOG's Avatar
Member Number: 11602
Yes. Just remember to pick the right one for the low beam headlight.
Michael
MADDOG is offline
Flickering headlights RobinVA Lighting Discussion 3 12-30-2010 05:20 AM
Headlights out/flickering wtf? glassfrogo2 Lighting Discussion 8 05-14-2010 12:57 PM
Flickering headlights AussieHemi Australia Forum General Discussion 29 10-06-2008 01:49 AM
Flickering headlights RobinVA Lighting Discussion 0 12-31-2007 08:42 PM
Flickering headlights AussieHemi Problems / Dealer Service 1 07-05-2007 01:53 PM
