Old 02-10-2007, 10:56 AM   #1 (permalink)
tbyrne
Car: 2006 . SRT-8
Member Number: 601
Smile INDY 6.1 Heads/Intake Dynoed +40hp
We bolted a set of INDY's CNC ported 6.1 heads and their intake on my SRT-8 this week and then I did some dyno testing today. Numbers were -
375.84hp/379.62ft-lb before this upgrade
407.49hp/396.00ft-lb after the head/intake install
That's about a 32hp improvement at the rear wheels and 40hp at the flywheel. Flywheel hp is up close to 510. Just a little higher than what we'll be seeing from the 6.4 when it's released in these cars in a few years.
The added power is really noticeable from 4000 RPMs to redline. I'm going to try to keep the stock cam in there... for now The ASM supercharger is looking pretty good too. I just don't want to turn this into a "race car". It will see some track action if the weather is good next weekend through.
Tom
tbyrne is offline
Old 02-10-2007, 11:01 AM   #2 (permalink)
hemiwagn
hemiwagn's Avatar
Member Number: 1684
Tom
cool
what exhaust are you running and does your car have a CAI?
2006 MSRT8
2006 Charger SRT8
NEW! 2005 300 Limited
1991 Chev Gettolier
hemiwagn is offline
Old 02-10-2007, 11:50 AM   #4 (permalink)
tbyrne
Car: 2006 . SRT-8
Member Number: 601
The car has Kooks long tube headers with cats and the stock exhaust. It breaths through the K+N induction. I'm thinking something bigger will feed it better. A stage II B&G tune takes care of the air/fuel.
tbyrne is offline
Old 02-10-2007, 11:59 AM   #5 (permalink)
greatone61
Car: 2006 Chrysler 300C SRT-8
Member Number: 4652
Is it me or the number's look low? At your rwhp of 407 your flywheel is 485 with a 16% driveline loss. 510 is with a 20% driveline loss, which I beleive these cars don't have.
greatone61 is offline
Old 02-10-2007, 12:11 PM   #6 (permalink)
teahead
teahead's Avatar
Member Number: 164
Where's the dyno chart?
W/the A/F readings?
NEXT MOD:
9" headrests, TVNav2Go
teahead is offline
Old 02-10-2007, 12:12 PM   #7 (permalink)
tbyrne
Car: 2006 . SRT-8
Member Number: 601
I was figuring about 50 at the flywheel but 40 isn't to bad. It would be nice to see what the actual % loss is between the flywheel and rear wheels. 5/6 speed cars usually have about 15% loss while automatics will lose more.
tbyrne is offline
Old 02-10-2007, 12:13 PM   #8 (permalink)
tbyrne
Car: 2006 . SRT-8
Member Number: 601
W/the A/F readings?
It's sitting next to me. I need to scan it at work
A/F was 12.31 at 5600 RPMs.
tbyrne is offline
Old 02-10-2007, 01:54 PM   #9 (permalink)
1fast400
Member Number: 3057
For some reason I thought the headers made it throw a code? Your first dyno seems similar for a mangaflow exhaust only modded car. I'd be curious what if anything you'd pick up from a magnaflow exhaust.
05 SRT-10QC in the 10's
SRT8 Magnum
05 Hemi Durango
1946 Dodge Panel Wagon
1950 Nash Ambassador
59 imperial 2 door
61 dodge seneca
62 imperial convertible
63 dodge 880 9 passenger wagon
65 barracuda
67 Fastback cuda
71 Dodge Demon 440
Two 71 duster race cars
Owner PiedmontDragway.com
1fast400 is offline
Old 02-10-2007, 02:44 PM   #10 (permalink)
JMatt
Car: 2005 Chrysler 300C SRT-8
Member Number: 1431
17.5% driveline loss.
3rd run always shows more HP than 1st run, as the trans/diff/etc loosen up once they warm up.
JMatt is offline
