Old 03-08-2007, 11:08 AM   #1 (permalink)
slimmbones
Car: 2006 chrysler 300c srt8
Member Number: 10304
Install 170 Stat (problem)
So I Installed New Stat, Problem The Temp On Dash Never Hits 200, But When I Go To On Board Computer In Systems Ok It Show A Range Bewteen 200-210 And My Gas Milage Is Gone, Meaning That Its Guzzling The Gas !
Help
slimmbones is offline
Old 03-08-2007, 12:45 PM   #2 (permalink)
330toSRT8
330toSRT8's Avatar
Car: 2006 Chrysler 300C SRT-8
Member Number: 4189
Send a message via AIM to 330toSRT8
The oil temp is different from the water temp. The analog gauge is water temp. The EVIC shows you oil temp unless you go into the hidden menu.
2006 Silver 300C SRT-8, purchased 12/27/05
- Silencer Removed, DIY Ram Air, Fan Mod & 170 Deg. Prestone
1967 Silver Camaro SS
pics @ arvizo.net
330toSRT8 is offline
Old 03-08-2007, 12:46 PM   #3 (permalink)
330toSRT8
330toSRT8's Avatar
Member Number: 4189
I've never heard problems with gas mileage. What do you mean it's gone? How many miles do you get before it's on empty?
Old 03-08-2007, 12:52 PM   #4 (permalink)
Hammbone
Hammbone's Avatar
Member Number: 11155
ewwwwwwwww.... whats the hidden menu?
Vehicles in the Lot-
06 Chysler 300C
*Lambo Doors from LamboFeaver.com
*Suede Interior (in process) PICS HERE
*22" TIS 07's
*DIY Custom Grill
*RaceReadyPerformance.com Electric Cutouts
05 Honda CBR 600 RR w/Mods
Hammbone is offline
Old 03-08-2007, 12:57 PM   #5 (permalink)
330toSRT8
330toSRT8's Avatar
Member Number: 4189
Hold down the music and compass buttons on the steering wheel for about 10 seconds. Then you will get a menu with several pages including speed, rpm, water temp, EVIC version, etc.
Old 03-08-2007, 12:59 PM   #6 (permalink)
greatone61
Member Number: 4652
Help
Are you sure you're not reading water temp?
greatone61 is offline
Old 03-08-2007, 01:04 PM   #7 (permalink)
slimmbones
It Just Seems To Be Sucking Alot More Gas, Or Maybe My Foot Is On The Pedal
Old 03-08-2007, 01:10 PM   #8 (permalink)
Hammbone
Hammbone's Avatar
thanks 330 i will have to try that...
Hammbone is offline
Old 03-08-2007, 01:15 PM   #9 (permalink)
slimmbones
What Should The Temp Run And Iam Looking At The Dial On The Dash Right Side?
Old 03-08-2007, 02:09 PM   #10 (permalink)
330toSRT8
330toSRT8's Avatar
Member Number: 4189
With my 170 tstat the normal reading is about 176 after the car has warmed up and I'm either cruising or have the fans on. If the ambient temps are above 100 then the water temp will probably be greater. Yes, it's the analog dial on the right side.
