Old 03-17-2007, 06:35 PM   #11 (permalink)
DennisG's Avatar
Car: 2006 Chrysler 300 SRT8
Member Number: 737
I just finished the install. It would be 100 times easier on a lift and a extra set of hands. But overall not too bad of an install. The stock X-pipe was a bit stubborn to get off the Cat pipes as expected. Squirted some WD and wiggled and jiggled the long heavy piece until it finally dropped off. That was probably the hardest part. Installing the new system was a breeze. I'm glad I spent the extra on a torque wrench. 45 ft lbs. is a lot tighter than I would have guessed. How many miles until I should check all the clamps?? BTW, sounds awesome! This system is definitely "drone free". Cruising on the freeway the normal person would not even notice the difference from stock. Very very slight difference, but WOT is much different. Thanks everyone for the pointers! Ready for the spring fling!! It's almost 90 degrees today, I guess winter is over!
2006 Brilliant Black 300SRT8
Showroom stock with 1500 miles 13.2@108.5 mph
DennisG is offline
Old 03-17-2007, 07:17 PM   #12 (permalink)
srt8danno's Avatar
Member Number: 1971
Congratulations on your successful install! I’m sure you’re really enjoying the new sound. Now you’re going to have to watch your mpg go down as you’ll be busy doing WOT’s all the time just to hear that sound! Enjoy.
srt8danno is offline
Old 03-17-2007, 11:05 PM   #13 (permalink)
NYC_SRT8's Avatar
Member Number: 5993
Trader Rating: (16)
Happy to hear everything went well. Check it after a few hundred miles or so. Good luck
Best - 12.3 @113 1.9 60ft
NYC_SRT8 is offline
Old 03-17-2007, 11:23 PM   #15 (permalink)
DennisG's Avatar
Member Number: 737
Thanks everyone! Airhammer and Corsa are music to the ears!
DennisG is offline
Old 06-20-2007, 11:50 AM   #16 (permalink)
Car: 2006 Chrysler SRT 8
Member Number: 10762
I may be blind but I haven't noticed what the average install time is for this exhaust system. I am debating doing this exhaust system or my brakes on my truck which is about 3-4 hour install time
Cichlids is offline
Old 06-20-2007, 12:02 PM   #17 (permalink)
NYC_SRT8's Avatar
Member Number: 5993
Trader Rating: (16)
2hrs max for the uninstall of stock exhaust and install of corsa.
NYC_SRT8 is offline
Old 06-20-2007, 03:10 PM   #18 (permalink)
MADDOG`'s Avatar
Member Number: 11602
Something to note...that crossmember isn't there to keep the exhaust from hitting the street...it's there to tie the body structure together across the span of the driveline tunnel. It's a structural member of the car and should be reinstalled!
MADDOG` is offline
Old 06-20-2007, 03:15 PM   #19 (permalink)
Car: 2006 Chrysler 300c SRT-8
Member Number: 11719
This was my second car to do exhaust on, but I'm generally not too experienced with doing such things. If not for high flow cat problems, it would have been ~2 hours, plus the additional re-torque of the clamps a day later which required getting it up on jack stands again.
JoshD is offline
Old 06-21-2007, 01:13 PM   #20 (permalink)
Car: 2006 chrysler 300 srt8
Member Number: 10085
DennisG ...LOL I had to do the same thing with my Lightning when I put the bassani on......I even tried to use a comealong to pull it off no-go
Im hoping that whn im ready the 300 will be easier to do, now all i got to do is find a very good price for corsa
Jaybo
Jaybo is offline
