Old 05-03-2008, 08:34 PM   #21 (permalink)
dynosteve's Avatar
Car: 2007 chrylser 300c
Member Number: 14734
Trader Rating: (18)
Originally Posted by 345CID View Post
So how does that differ from the diablo? or does it?
diablo is the handcontroller and cmr is the tuning software that sends a custom program to the handcontroller
WWW.RDPMOTORSPORT.COM
Diablosports Only Australian Importer and Distributor of Predator units.
Supercharger kits, Turbo kits, Custom CMR Tuning, Cai Units, Exhausts, CMR Custom Email Tunes.
NEW USA STORE OPENING SOON
dynosteve is offline
Old 05-04-2008, 04:14 PM   #22 (permalink)
Vader's Avatar
Member Number: 16843
I'm now going on 12,000 miles with my GSM kit. I drive my car 40 miles every day. The supercharger was installed at the 400 mile mark. After about 4,000 miles, I removed the R4 controller, disconnected the auxilary injectors, added the SMT6 controller along with colder plugs and 39lbs injectors. It was a good set up prior to the Diablo coming out. Now that the Diablo is out, my car's currently at Injected Engineering getting a boost-a-pump installed, along with 55lb injectors, 2-bar map sensor and a custom tune with the Diablo. I have had no issues with my GSM kit other than a slight leak coming from the oil return line (just had to reseal it). Unfortunately because GSM had the first kits for our cars, and it was at a time period when only piggy-back systems were available, some things did go very wrong. No doubt all of the other vendors learned from others mistakes.
Vader is offline
Old 05-07-2008, 01:06 PM   #23 (permalink)
IGOTTASRT8's Avatar
Member Number: 2287
At the risk of sounding stupid. Exactly what does CMR tuning stand for and what does it mean. I understand the Diablo can retune the car through the cars computer but the CMR thingy has me confused.
-John
CMR Tuning - Professional tune done by an experienced tuner (via the cars computer), usually with the aid of a dyno. Once completed, this tune can be loaded into the car directly OR the Diablosport Predator which is a handheld tuner that anyone can buy and make little tweaks to their tune.
Diablosport Predator - A handheld tuner that comes pre-loaded with a couple of performance tunes. These tunes were achieved by a professional tuner using CMR software.
A person who installs any kind of power adder should get a custom tune (via CMR) that can be tailored way beyond the capabilities of the Diablosport handheld tuner.
NX Nitrous Kit With Maximizer 2
Diablo Predator Tuner
GSM Track Mod
Mopar CAI
Zoomers Exhaust
Stant 170 Thermostat
12.2 @ 116 1.99 60ft Famoso Dragstrip
IGOTTASRT8 is offline
Old 05-07-2008, 05:41 PM   #24 (permalink)
Husker's Avatar
Car: 2006 Chrysler 300 SRT8
Member Number: 8326
Originally Posted by IGOTTASRT8 View Post
I read the story that you are referreing to and that guy had the old "auxillary injector" setup.
I HIGHLY doubt that this will be happening with the new CMR tuning. You guys really need to know the difference between the two to make an educated decision....or comment on the matter.
Well first of all that just happend and the car was not very old...almost brand new. Two, if they still use anything like the "aux injector" it will still fail as the intake is designed to be dry and not wet. So under normal city driving the front two cyl just burn up from lack of fuel. The ONLY way to do this is the way the DynoSteve is doing it..and no I don't know him, but that setup is designed to work correctly from the start. A different tune is NOT the answer to that design..I beleive GSM has also changed to larger injectors. But thanks for your input
Red Inferno Magnum SXT-sold
Red Inferno Magnum R/T- sold
Silver 2006 300C SRT8
Options I,II SunRoof and Side Curtain Airbags
I just LOVE the LX platform!!!!
Wife's
05 Garnet Chevy Suburban Z71
Husker is offline
Old 05-07-2008, 09:26 PM   #25 (permalink)
DanRealtor's Avatar
Member Number: 3102
New Kits
The new kits do not use auxiliary injectors. The fuel is via larger injectors only. The fuel tables are adjusted using the CMR software. While there have been some engine failures using the original design, there are literally thousands of cars running the original kits without a hitch. The next generation of supercharger is the I-Charger. With it's amazing efficiency and unique, compact design and linear power curve, it is really amazing to drive!!!
It Wasn't Me
(well, maybe once it was)
DanRealtor is offline
Old 05-07-2008, 09:55 PM   #26 (permalink)
Husker's Avatar
Member Number: 8326
I feel it was the lack of understanding of the intake design that caused so many issues. Let's face it, NO ONE can say it was easy to tune these cars prior to Diablo and their software..But like all new cars, time always fixes the issues.
Husker is offline
Old 05-07-2008, 10:09 PM   #27 (permalink)
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (4)
Just do a search on GSM here and over at lx forum...that should be enough to make you think twice. Unless you gots lots a cash to replace motors
And I'll bet most of those were either 1. pre-tuning or 2. user adjusting things after initial set up like increasing boost.
Now that GSM has the tuning, and they are damn good at that, the problems are all but gone from what I have tracked...but again, the operator must not go against what I call rules of engagement.
Think about how many GSM cars are out there with no problems vs. a few after tuning that are tearing up the roads? Just like any power adder you are always up against potential problems.
Do you mind posting the link here on the one you say just happened?
I think Scott and GSM is totally worth checking out if you are in the market to make your car a beast!
Moose.
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back Calendar Winner
Moose is offline
Old 05-08-2008, 12:07 AM   #28 (permalink)
monstergarage's Avatar
Car: 2007 Chrysler 300c srt
Member Number: 17320
thanks everybody this thread just keeps getting me better informed. i learn something new after every post. i-charger huh?, def have to look into it.
K&N cai, Magnaflow catback, Predator, and more to come
monstergarage is offline
Old 05-08-2008, 08:31 AM   #29 (permalink)
Husker's Avatar
Member Number: 8326
Moose.
Here is the link, it's not what I say happened..it IS what happened. Look, if they guy is lookig to invest alot of money, he should get ALL the info he can.
I am not goingto bash any vendor, many have already done so to alot of the early adopters, but I will say that the "aux injector" design was not a good one... and leave it at that
srt8 carnage, mid teardown - LX Forums Modern Mopar Muscle
Husker is offline
Old 05-08-2008, 05:27 PM   #30 (permalink)
IGOTTASRT8's Avatar
Member Number: 2287
GSM has abandoned the auxillary injector design and is now tuning it the same way DynoSteve is tuning.
