Old 05-19-2008, 05:59 PM   #21 (permalink)
Lik2race's Avatar
Car: '08 Diffent Kind 4dr
Member Number: 1183
Thumbs up
Originally Posted by Chase300 View Post
That suitcase is a major choke point for the SRT exhaust. If I had a SRT 6.1, I would remove it ASAP. Why? Because it the same exact muffler as the 5.7L performance exhaust and that muffler is only 2.25" diameter piping, while the rest of the SRT 6.1 exhaust is 2.75". So you have exhaust flowing out the headers into 2.75" piping, then pinching down to 2.25" at the suitcase, then at the suitcase outlet, back into 2.75" piping to the resonators. Simply removing that suitcase should give you the largest improvement in exhaust flow for very little coin.
This is so true...
I would like to get some Flowmaster 50 Series as my next big project.
( passing the hat ).....
Lik2race..Use 2 B SRT8 GUY
Lik2race is offline
Old 05-20-2008, 07:13 AM   #22 (permalink)
Member Number: 6420
Unless you change to high-flow cats, nothing you are doing to your exhaust is making much of a difference...other than turning up the volume. Go to a dyno and check if it "feels" faster.
Eric
AFE II intake, 185 t-stat, BT catch can, Predator with CMR tune, CORSA & MF cats
*Stock best with AFE intake only: 12.949@109.17 w/2.009 60' - 8.406 1/8 mile on 10/11/07 DA +100 Tri-State Dragway Cincinnati
*With a tune & intake: 12.649@113.98 w/1.945 60' - 8.219 1/8 mile on 5/28/08 DA +600 Muncie Indiana Dragway
*Intake/exhaust/tune 12.54@112.1 on street tires!
EricG is offline
Old 05-20-2008, 10:08 AM   #23 (permalink)
Member Number: 7149
Eric
So the first choke point is the factory cats...then the suitcase. You'll have to do both as you probably won't see any gains or very little from high flow cats with a suitcase that constricts the exhaust from 2.75" down to 2.25".
Chase300 is offline
Old 05-20-2008, 10:15 AM   #24 (permalink)
CSJBOAT's Avatar
Car: 2007 Chrysler 300c
Member Number: 17870
Blastin Bob's 11db res. replacement pipes sound awesome on my 300c. I made the mistake of removing the suitcase, had to put it back on. Leave the suitcase & get the 11 db res. replacement pipes! I believe you will be happy.
2007 300C
CURRENT MODS:
Cai w/ custom ram air from lower fender
Preditor
Blastin Bob's 11 db res. replacement pipes
180 t-stat
Throttle body spacer
CMR from Johan @ Diablo
Now 313 hp 355 tq @ wheels @ 90 hot degrees
I want
long headers
! Too much $$$
13.9 @ 100 @ MOROSO
CSJBOAT is offline
Old 05-20-2008, 10:23 AM   #25 (permalink)
Member Number: 6420
Well I don't know about that.
I'm just saying that unless you unchoke it at it's first point after the exhaust manifold/header, you're not seeing much gain...if any at all.
Eric
EricG is offline
Old 05-21-2008, 11:17 AM   #26 (permalink)
Performance Moderator
Car: 06 Deluxe! CSRT8
Member Number: 3650
sheesh
the forum is full of real life experiences to back me up... exhaust work on these cars rarely nets anything but noise without careful tuning.
Yet another example... my good friend Jeff got an 07 Charger SRT8 (stole it!) and we immediately began "performance testing". His car was a tick slower than mine (stock program), about 1.5 lengths from 0-90 mph. We expected this as he has 700 miles and I have 26000.
He immediately went out and removed the resonators, and even I love the sound outside. Inside is way too loud at certain speeds for my taste. But the funny thing is his car was actually slower!
Haven't done any data logging on him yet but we will and I bet we can tune his car to make the exhaust work perform better. But stock tune just does not like mods.
Steve
06 300C SRT8
Only mod is new Toyo Proxes 4
245/45 front 275/40 rear
stevesrt8 is offline
Old 05-21-2008, 09:44 PM   #27 (permalink)
Member Number: 7149
Those results are not surprising given our speed density system we have. As you said, you will not see much gains with mods to intake and exhaust until you tweak the ecu. The speed density system just can't make much adjustments to take advantage of increase airflow. However, once tuned for such, the improvements should be quite good.
Chase300 is offline
Old 05-21-2008, 11:15 PM   #28 (permalink)
topfuel67's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 9144
What people don't realize (I was one of them when I did the suitcase delete) is this isn't your 60s muscle car where you can stick the fattest pipe and biggest mufflers to get the best performance. The exhaust needs to be tuned to this car. I've personally seen the magnaflow system gain hp on the dyno.
Mods:
Diablo
Corsa Exhaust
185 T-stat
275/40/20s
AFE Stage II CAI
Mopar Grill
topfuel67 is offline
Old 05-23-2008, 01:14 PM   #29 (permalink)
SHARK22's Avatar
Car: 2006 Chrysler SRT 8
Member Number: 12183
Topfuel!
You need to have a predator or something of that nature to change the settings on the CPU to realize the gains with a Dyno and exhaust correct??
2006 300 SRT8 Black
22" Demoda Symphony's wrapped in Nitto NT 420s
Mopar Intake
Throttle Body Spacer
Magnaflow Exhaust
Centric Posi Quiets - A must have!!!
SHARK22 is offline
Old 05-23-2008, 02:43 PM   #30 (permalink)
jblue21's Avatar
Car: 2006 Chrysler 300c SRT-8
Member Number: 15700
CMR tune to be exact
My cars
*2006 300 SRT-8 21,000 miles with the diablo predator and CAI, T-REX grille-fully loaded, 22" crome viper replicas w/nitto 420s stag
*2004 Mercury Marauder Orignal Owner-22,000 miles Vortec Air-to-Air S/C Kit 450rwHP+ w/many other mods(4.10 gears, SCT custom tune etc.)
**I'm from Detroit, we don't find anything charming**
**I like fast cars but I aint talkin five-O's**
jblue21 is offline
