Old 01-06-2010, 01:34 PM   #1 (permalink)
Points: 2,260, Level: 1 Points: 2,260, Level: 1 Points: 2,260, Level: 1
Member Number: 11560
cam and breaks
hi to all happy new year last summer i installed a cam from PPP the runs great
but i have notice that the breaks feels different my mechanic told me that the cam was sucking more air or the air in the breaks master cylinder or something like that i am not sure but it seems that if i pressed the pedal twice the feeling of the pedal goes back to normal i was told by doing so i am pumping air into the system i guess plz plz i need help
KSA SRT8 is offline
Old 01-06-2010, 01:46 PM   #2 (permalink)
Points: 6,053, Level: 1 Points: 6,053, Level: 1 Points: 6,053, Level: 1
AP24LA's Avatar
Car: 2007 chrysler 300c & SRT8
Member Number: 18958
Trader Rating: (4)
Heres a quick bump for ya. Im not 100% sure but I highly doubt that a cam would have anything to do with your brakes other than you using them more often because of driving at higher speeds. Im sure somone alittle more knowledgeable than me will chime in. Good luck.
DiabloSport Predator
AFE Stage II CAI
185 Tstat
10000k HID lows and fogs
Halos
Resos and suitcase delete
AAC LED Kit
Demoulded & debadged
tinted tails
22" gloss black SRT reps
255 toyo proxy 4s
VDI Lambo Doors
AP24LA is offline
Old 01-07-2010, 02:36 AM   #3 (permalink)
Performance Moderator
Points: 15,358, Level: 1 Points: 15,358, Level: 1 Points: 15,358, Level: 1
Car: 06 Deluxe! CSRT8
Member Number: 3650
yes and no
A cam could affect the brakes by lowering the vacuum. The brakes use vacuum to boost the pedal pressure.
But your last comment is a clue. If you simply pump them back up to normal with your foot then it's not vacuum.
These cars suffer from "pad knock back", where the pad is moved by the rotor under hard cornering. This is not repairable, but it can also indicate it is time for new pads.
And last, bleed those brakes. Could just be a bubble or two in there.
J. William Fulbright
Steve
06 300C SRT8 all stock
stevesrt8 is online now
