I just installed the AFE Stage II Intake with the dry filter on my 2006 300 SRT8. When I hit the throttle at 60MPH + on the highway the car seems sluggish(And this is with the 93 CAI Perf Predator Tune) and makes a choppy sound, like it is not getting enough air. Hard to describe. THe AFE did not have the rubber gasket for the MAF sensor, so I made one from a little silicone and electrical tape. Does the MAF have to be positioned a certain direction to work properly? I think this may be the problem? THe first gear take offs are sick, but seem sluggish at speed when more air is coming through the intake. Thanks for the help...
There is no rubber gasket around the MAF that needs to be included, you pull it out of the stocker and put it in the AFE. Point the open end into the airflow. If you rub a little WD-40 onto your fingers and lube up the base of the MAF it goes in with a little finesse.
2006 Chrysler 300C SRT8
- now Magnaflow HF cats, CORSA and Predator with CMR tune by Ken Bjonnes at DCX Depot...and a 185 t-stat & BT catch can Bests(all done on Toyo 255s):
That was my concern. I sold him the AFE, and didn't send him any rubber grommet because the only one I had was the one that came on the car from the factory. I'm assuming that the factory one is still left in his stock intake.
At 60 mph and in D you'll be in 5th gear and about 2100 RPM IIRC... not exactly the power band of these cars. With the 93 CAI tune you should downshift with aggressive throttle action and burst into the power band... but you didn't mention the tranny downshifting, only that the car was sluggish.
Try manually downshifting to 4th (autostick bump left) or even 3rd and then hit the throttle. It should set up back in your seat quite nicely. You can approach 110+ mph by redline in 3rd ya know)... at least that's been my experience at the track.
Actually, in D, you'll upshift into 4th at around 118 under WOT....since I've never been above 140ish, I don't know if there's a WOT shift point into 5th...I can imagine that a throttle position above a certain value (85%, perhaps?) will prevent the car from shifting into 5th in D....
Dream upgrade package (not ones I already have!!):
