Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > SRT8-Specific Problems/Dealer Service
Old 11-29-2008, 07:55 AM   #1 (permalink)
Points: 953, Level: 1 Points: 953, Level: 1 Points: 953, Level: 1
Matt Harper's Avatar
Car: 2007 Chrysler 300C SRT-8
Member Number: 19881
Smokey cold start-up (Moved)
I have a 2007 SRT-8 with 30k miles on it. I've owned it for about a month.
Maybe it's just a cold snap we've been having here in FL for the last week, but I noticed that there is a big cloud of smoke out of my exhausts when I start it from cold. Is this normal?
I ask , because years ago, I had a 5.7 IROC Camaro and a smokey exhaust was the first sign of valve seal failure. My SRT has a warranty, so if there is an issue, I believe it will be covered.
So, normal or not? The car seems very well cared-for, but maybe had a lot of hammer before I got my hands on it. Can anyone advise me please?
Regards
Matt
Matt Harper is offline
Old 11-29-2008, 08:30 AM   #2 (permalink)
Performance Moderator
Points: 15,325, Level: 1 Points: 15,325, Level: 1 Points: 15,325, Level: 1
Activity: 43% Activity: 43% Activity: 43%
Car: 06 Deluxe! CSRT8
Member Number: 3650
oily intake
on most SRT8's this is caused by built up oil in the intake manifold.
A catch can will help, as will an "italian tune up"!
We have very few valve seal issues on stock heads. These motors are nearly bulletproof stock. You may need to change to a less volatile oil if you're getting too much blow-by.
J. William Fulbright
Steve
06 300C SRT8 all stock
stevesrt8 is offline
Old 11-29-2008, 08:41 AM   #3 (permalink)
Points: 3,369, Level: 1 Points: 3,369, Level: 1 Points: 3,369, Level: 1
khaleal's Avatar
Car: 2006 Chrysler 300C SRT8 Silver Steel
Member Number: 4643
Mine has just recently done the same thing once the temp in Arizona dipped below 50 degrees, but that has been the only time in 2.5 years....I would not worry about it, unless it becomes more frequent.
More pics @ khaleal on car domain
khaleal is offline
Old 11-29-2008, 11:28 AM   #4 (permalink)
Points: 1,307, Level: 1 Points: 1,307, Level: 1 Points: 1,307, Level: 1
SRT8_T's Avatar
Car: 2006 chrysler 300C SRT8
Member Number: 20075
in cold weather and most of the time from a cold start, it looks like smoke but its just water vapor from the exhaust almost all cars do this nothing to worry about unless your car is warmed up and smoking.
SRT8_T is offline
Old 11-29-2008, 12:10 PM   #5 (permalink)
Points: 1,837, Level: 1 Points: 1,837, Level: 1 Points: 1,837, Level: 1
mpouls1's Avatar
Car: 2009 Cadillac CTS-V
Member Number: 15376
Not to threadjack but speaking of cold weather, when its around 30 or lower when I first turn the motor over it get this harsh sounding whine that lasts for a split second or so. Is that a pulley or the power steering pump? Can't really think of a better description but I'm sure I can't be the only one.
mpouls1 is offline
Old 11-29-2008, 09:09 PM   #6 (permalink)
SRT8_T's Avatar
could be the air pump (notr sure if these have them) does it sound like vaccum? or it could just be the starter your hearing. hard to say without hearing.
SRT8_T is offline
Old 11-30-2008, 12:27 AM   #7 (permalink)
mpouls1's Avatar
It does not sound like an air pump or vacuum. My old 97 deville had a water pump that went bad and it sounded a lot like it. Not the high pitched whine of bearings squealing. Doesn't sound like a starter either. More like a pulley that is not lubed or something. I really can't describe it. Like when you take a shopping cart wheel and spin it real fast and there is a wobbling noise.
mpouls1 is offline
Old 11-30-2008, 07:34 AM   #8 (permalink)
Member Number: 3650
check out...
this sounds a lot like oil squirter whine. Only on SRT8's. It has been likened to supercharger noise, but to me it reminds me of a bad power steering pump.
You can change to 15w-50 oil per TSB and see if it changes/eliminates the noise. It only reduced it on mine.
It's normal and is not an indication of impending failure.
Old 11-30-2008, 09:27 AM   #9 (permalink)
Points: 8,103, Level: 1 Points: 8,103, Level: 1 Points: 8,103, Level: 1
Member Number: 1483
Sounds like a diesel air starter? This is a long-time known phenomenon. It's the power steering fluid cavitating upon initial startup. No problem. Proportedly it can be improved/eliminated by changing to synthetic fluid. Not worth the grief.
DESIREE is online now
Old 12-01-2008, 08:59 AM   #10 (permalink)
Points: 10,413, Level: 1 Points: 10,413, Level: 1 Points: 10,413, Level: 1
Activity: 38% Activity: 38% Activity: 38%
Member Number: 6420
Valve guide seals are not a known problem for these motors.
I'd look into a weak gasket around the intake for the cause of your oil leak, especially if the car has intake spacers to keep the top end cooler. Even the stock gaskets can fail, apparently they are not very good - at least that's what I heard from a tech at the local Dodge dealer.
I only say this because I had a friend working forever to try to track down his smokey start-up source, turned out it was the gaskets around the intake, but he had spacers. Good luck.
Eric
Bests(all done on Toyo 255s):
EricG is online now
