Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > SRT8-Specific Problems/Dealer Service
Old 03-21-2009, 11:10 PM   #1 (permalink)
Points: 12, Level: 1 Points: 12, Level: 1 Points: 12, Level: 1
BL ICE's Avatar
Car: 2006 CHRYSLER 300C SRT8
Member Number: 21541
Angry 06 Srt Keeps Hitting Fuel Cut On Hard Excelleration Around 4,300-5,000 Rpm (Moved)
Hello, Everybody Im New Here But Not New To Nice Rides ! Can " Anybody Help " ? I Have A 2006 300 Srt About 30,000 Miles, The Car Randomly Cuts Off While Sitting At Stop Lights Or Where Ever , Never While Driving Though , Only After I Have Come To A Stop. The Car Idles Like Normal, Also The Will Hit What Seems Like The Fuel Or Spark Cut At Around 4,300-5,000 Rpm At W.o.t. Starting At Different Rpms , It Has Done It At 30 Mph, 40 Mph , 50 ... But Randomly ! ! But It Is Alot More Noticeable Than The Other Problem. I Have Had It At The Dealer Afew Times Already But They Haven`t Fixed The Problem Yet ! ! They Have Replaced The Throttle Body, Some Trans. Recall Part, And As Of Friday 3/20/09 They Said That The ( Tcm) Had A Intermittient Loss Of Communication To ( Tcm ) And Replaced (tcm) Relay. Took It Out Last Night To Test It Out And Guess What , It Cut Off On Me At A Light And When I Got On It , It Still Hit The Fuel Cut Or What Ever. The Only Performance Mods I Have Done Are A Dub Intake And A Magnaflow Exhaust ( Cat. Back ) . Can You Help ? ? ? ?
BL ICE is offline
Old 03-22-2009, 08:06 PM   #2 (permalink)
Points: 9,134, Level: 1 Points: 9,134, Level: 1 Points: 9,134, Level: 1
DaveW68's Avatar
Car: 2006 300C SRT-8 WHERE ARE YOU DANNO?
Member Number: 4952
To me, it sounds like there are issues with the ECM (electronic control module), which I believe is the main computer in our cars. The ECM may just be in need of an updated tune from the Startac. I wonder if a Predator tune would alleviate the problems? I have a feeling that it may. The Predator will automatically update the ECM to the latest tune, or close to it. If you haven't already picked up a Diablosport Predator tuner, I highly recommend that you do so. Your car will just perform so much better than stock.
Hey America, how's that hope and change working out for you?
DaveW68 is offline
Old 03-23-2009, 12:48 AM   #3 (permalink)
BL ICE's Avatar
Thanks , I`ll Give It A Try If The Dealership Can`t Fix It. Does The Pred. Automaticly Reprogram The Ecm Or Do You Have To Tune It Yourself And Hope You Got It Right ? I Already Have A Jet Performance Plug And Play Device But I Haven`t Installed It Yet. Does The Pred. Reflash The Ecm Or Reprogram And Can You Return The Ecm Back To Factory Settings ? Thanks Again !
BL ICE is offline
