Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > SRT8-Specific Problems/Dealer Service
Old 03-24-2009, 07:16 PM   #1 (permalink)
TTP
Points: 4,841, Level: 1 Points: 4,841, Level: 1 Points: 4,841, Level: 1
TTP's Avatar
Car: 2005 300C SRT-8
Member Number: 11268
Exclamation Interior electrical problem..(Fuse??) (Moved)
Hi!
About 2 weeks ago I lost my interior lighting and some of my dash lights but not all as my Navigation and steering wheel lighting is still intact.
I figure it could be a burned out fuse , however I can't find a match for which fuse it could be when I researched this in the car manual.
Any thoughts or suggestions.
PS..Since this had happened I have had to replace my battery with a brand new one,,still have the issue with the interior lighting.
Thanks for any help!
Trevor
<img src=http://www.nextlevelav.com/forum/attachment.php?attachmentid=947&stc=1&d=1179030968 border=0 alt= />
2005 300C SRT-8
#54 of 252 North America (excl. 11 pilots)
#6 of 35 Canadian (excl. 8 pilots)
TTP is offline
Old 03-24-2009, 07:28 PM   #2 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
is it all the interior lighting?
the overhead, the dash, the A/C controls, etc?
if it is check the dim button on the headlight switch, see if it rolls up and down, I've seen a few cars where it stops rolling as the switch breaks away from the board, with the dash lights in the full dark position..
the switch will roll, but not do anything.. so it will need to be replaced... (and yeah it drains the battery, some kind of short in the switch when this happens)
Mr. iNCREDIBLE is offline
Old 03-24-2009, 10:38 PM   #3 (permalink)
Points: 4,175, Level: 1 Points: 4,175, Level: 1 Points: 4,175, Level: 1
slabhurta02's Avatar
Car: 2007 Chrysler 300
Member Number: 11432
I'm kind of having the same problem and I noticed it started after my battery goind dead about a month ago and I jumped it with another car. Whenever I turn off my car with the ignition key and remove the key, my door lock controls no longer work and my interior lamps do not illuminate when a door is ajar, and nothing works until I turn the car back on all the way.
slabhurta02 is offline
Old 03-25-2009, 10:42 AM   #4 (permalink)
Member Number: 5683
Trader Rating: (21)
yeah, one or more of the modules on the canbus needs a reset, it is stuck in a loop.. need a star scan to reset them all..
these cars do not like dead batteries, it wreaks havoc on the network, they also do not like to be jump started, I've seen 2 guys local that fried their FCM's getting jumped..
Old 03-25-2009, 05:52 PM   #5 (permalink)
TTP
TTP's Avatar
Thanks,
I am pretty sure it's not the light dimmer button. Sounds like it may be the modules. I will call Dodge and have everything reset.
Dead Battery and Boosting is what likely buggered everything up.
TTP is offline
