Old 01-08-2006, 08:41 AM   #11 (permalink)
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (9)
Originally Posted by DucatiBoy
My question is what is the $180 for the TPMS senser stuff? I would consider ordering these. And with the pitting on the original rims, it's probably a good idea to run different rims in the winter.
You don't need to worry about the Tire Pressure Monitoring Sensors (TPMS) on your 5.7 liter 300C. It's only a requirement for the SRT8.
Dave Zeckhausen
Owner, Zeckhausen Racing
DZeckhausen is offline
Old 01-08-2006, 10:52 AM   #12 (permalink)
tommy's Avatar
Car: 2004 SI HATCHBACK HONDA CIVIC
Member Number: 4417
i figured RWD cars could never drive good in the snow even with snow tires lol. guess i am wrong . cool
2006 SRT-8 in silver steel
navi , 15%tint, planet audio gear.
2004 Honda Civic SI in tafetta white
lowerd
ukdm H.I.D projectors
R1 racing gtr 10's in hyperblack w/polish lip
tsunami body kit
tommy is offline
Old 01-08-2006, 11:21 AM   #13 (permalink)
marnepup's Avatar
Member Number: 2139
Oh...I dunno...they do fine with 800lbs in the trunk
Silver 2006 300C SRT8
Built 25 November 05
Mods:
H10 Fogs (close, but not perfect color match)
22elite console cover (passenger satisfaction up 11%)
MOPAR sticker (worth 15 RWHP)
Valentine One (haven't been ticketed yet...)
K&N filter for stock air box
Proxes 4 275s all around
Diablo canned tune
Planned:
Corsa
90mm TB
PPP Heads, intake, and cam
AFE stage II
CMR tune
marnepup is offline
Old 01-08-2006, 11:27 AM   #14 (permalink)
Member Number: 1056
Trader Rating: (9)
You would be amazed by what almost any RWD car can do with a set of Q-rated Blizzaks. Even a Fox chassis Mustang can do OK.
On the other hand, the addition of a real limited slip differential would help even more, especially when climbing a steep hill in the snow. My BMW 540i 6-Speed came with an open differential, just like the SRT8. After a frustrating winter spent making multiple attempts to get up the hill while spinning one rear wheel, I broke down and installed an M5 limited slip. This was an expensive proposition, requiring the installation of the M5 driveshaft and halfshafts too. But I can now climb the steepest hills by switching off the traction control, spinning the rear wheels (both of them!) and using a little opposite lock on the steering as necessary. A snow tire gets the best traction when there is some slip. And in the summer, when nobody is looking, I can switch off the stability control and make a glorious power slide!
Does anyone know if there is an aftermarket limited slip differential available for the SRT8?
Dave Zeckhausen
Old 01-08-2006, 11:39 AM   #15 (permalink)
Meister's Avatar
Member Number: 942
...My BMW 540i 6-Speed came with an open differential, just like the SRT8. After a frustrating winter spent making multiple attempts to get up the hill while spinning one rear wheel, I broke down and installed an M5 limited slip. This was an expensive proposition, requiring the installation of the M5 driveshaft and halfshafts too. But I can now climb the steepest hills by switching off the traction control, spinning the rear wheels (both of them!) and using a little opposite lock on the steering as necessary.
...Does anyone know if there is an aftermarket limited slip differential available for the SRT8?
Dave, it will be interesting to see your report after you have a chance to tackle that same hill, under similar conditions, with your SRT8. I'll be highly surprised if you don't discover that the LX open differential is much, much, more effective than was your Bimmer's.
No, no aftermarket limited slips are yet available for the LXs.
TPMS is standard on 300Cs BTW starting with model year 2006.
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
Meister is offline
Old 01-08-2006, 11:57 AM   #16 (permalink)
Member Number: 1056
Trader Rating: (9)
Now all we need is some snow to motivate me to install the Borbet wheels & squishy Blizzaks. It's 45 degrees today and Weather.com says it will be raining on Wednesday and Saturday with temperatures above 50 degrees. With a fully prepared snow blower and winter wheels on hand, I may have just single-handedly prevented any more snow from falling for the rest of the winter!
I'm curious why you think the SRT8 open diff will be any better than the BMW's system. Both have stability control/traction control systems that try to maximize torque to the wheel with traction by applying a single brake to the spinning rear wheel. Is the SRT8 system more advanced in some way?
Bummer - I think.
I'll see if you you're correct about the SRT8's open diff being more effective. If this is not the case, I may look into commissioning someone to build a Torsen or Quaiffe limited slip for our cars.
Really? I didn't know that! This becomes an issue when selling used 300C (5.7) factory wheels, if the buyer has a new car. I'll keep my eyes open and make sure to warn others if they are on the verge of discovering it the hard way. Thanks for the info.
Dave Zeckhausen
Old 01-08-2006, 12:02 PM   #17 (permalink)
tommy's Avatar
Member Number: 4417
oh ok . i thoguth the srt-8 came with limited slip . question , is that the same as a posi rear? i assumed so . i guess they dont make a AWD version either . only 300c not srt-8
lowerd
tsunami body kit
tommy is offline
Old 01-08-2006, 01:39 PM   #18 (permalink)
Member Number: 1056
Trader Rating: (9)
"Posi-traction" is Chevrolet's brand name for limited slip differential, but like "Kleenex" has become a more widely used generic term. Pontiac called their LSD "Safe-T-Track" and Ford called it "Trac-Lok". Chrysler used the term "Sure Grip". Whatever you call it, the SRT8 does not have it.
AWD is only available (and standard) in the SRT8 Jeep. The Magnum, Charger, and 300C SRT8 have open differentials.
Dave Zeckhausen
Old 01-08-2006, 05:50 PM   #19 (permalink)
Mopar Time?'s Avatar
Car: 2006 Chrysler 300 SRT8
Member Number: 1852
DZeckhausen
Didn't know you were moving from a 5 series to the SRT8. I currently drive a 2000 528 Sport, and run snow tires on all four corners these past 5 years. If the SRT8 is as good as my car is in the snow I'll be very glad. I can climb hills that front wheel drive or even some 4 wheel drives can not. The modern day electronics make a huge difference.
What are your impressions after driving a BMW and then going to the SRT8 ?
I am interested in your opinion, since I only test drove an SRT8 for about 10
minutes and did not get the day to day comparison chance between my current 5 year daily driver.
Thanks,
Mopar Time? is offline
Old 01-08-2006, 06:26 PM   #20 (permalink)
sjz
sjz's Avatar
Car: 2006 SRT8 300C
Member Number: 964
Don't take all the credit, Dave. I put a new carb on my snowblower a few weeks ago, & bought a used Jeep GC, ensuring that we won't see any snow!
-Steve
Brilliant Black
Goodyear AS, Sunroof
Groups I & II, Kicker
Built: 7/1/05 at 7AM
Mopar CAI
Jeep OEM underhood light
TCM flash TSB #: 21-020-06
____________________________
1967 International Scout 800
345 cid V8
---- The FIRST SUV----
sjz is offline
