The bottom line is that EBC Greenstuff is unusually prone to pad deposition issues. Typically, someone installs a set of these pads and reports back that they love the dust reduction. Then 30 days later, they complain about their rotors "warping." The rotors are just innocent bystanders and are not warped. They simply have uneven pad deposits. See: http://stoptech.com/tech_info/wp_warped_brakedisk.shtml for some excellent background on this issue.
EBC Troubleshooting: http://www.ebcbrakes.com/TroubleShooter.html
EBC Greenstuff problems are REAL. I installed Brembo drilled rotors and EBC Greenstuff pads on my 5-Series BMW last year and was THRILLED with the results.
The brake dust problem virtually disappeared.
Then a month or two later I started experiencing vibration during braking. This increased gradually until I had to apologize to passengers for the vibration, and the car even began to vibrate on the highway even when I wasn't braking (lost some wheel weights too?)! I figured that I had smoked the rotors somehow by driving too aggressively (who me?) and decided to buy new rotors instead of turning the old ones.
So, after I had enough, I installed new front rotors and was pleased once again (although there was still some vibration as I didn't replace the rear rotors).
...yup, one to two months later the vibration began again.
ARRGGGHHH.
I noticed that the Tire Rack had a footnote on their website for Brembo drilled rotors "we do not warrantee drilled rotors against warpage" -
I blamed the rotors.
I was going to replace all rotors with the standard non-drilled units when I stumbled across a post regarding this phenomenon on THIS wonderful forum. The website had pictures of "warped" rotors from this and there were dark spots on the faces of the discs.
I pulled the discs and sure 'nuf... there were the spots!
$50 later and I installed the newly-turned rotors back on the car and followed the "bedding" procedure described in Zeckhausen Racing's website
http://www.zeckhausen.com/bedding_in_brakes.htm
I got my brakes so hot there was smoke coming out of the fenderwells.
That was Sunday night. The brakes feel great now, and there is NO VIBRATION at all, even on the highway
(this part doesn't make sense to me... I can't believe that I warped the rotors so bad that they threw the wheels out of balance ? ).
Anyway I am happy, but I haven't driven the car enough to convince me that this won't happen again even after properly bedding the pads.
I won't run the risk with the SRT8. I will install a different set of pads to get rid of this damn brake dust problem, but not EBC AnyStuff.
One comment regarding drilled rotors:
I have installed drilled rotors on two cars and the only difference I noticed was the noise and buzzing feel from the holes when braking. They look cool, but I will NOT install drilled or slotted rotors on the SRT8.
The SRT8 brakes feel so nice after living with the "buzzing" from my BMW drilled rotors for so long, I will never do this again.
