Old 01-14-2008, 04:37 PM   #1 (permalink)
Diesel Powered
Diesel Powered's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 14069
Vibration at 80mph
Here's the setup. I have 14K miles on the car. Had the stock Goodyear F1's on the car, and everything was fine.
Just had some new Toyo Proxes 4 (275/40 rear; 245/45 front) and now when I get up to 75-85mph, I get a real bad shake in the wheel. Obviously not pleased, I went into and had the alignment done today on the front and rear just to make sure.
When I got back onto the interstate I am having the same issue. I have read some ideas on the Tie Rods, however I don't think the coincidence is too far off that I have only had this problem with the newly mounted tires. With that said, I also don't believe the issue is with the new tires (see how I circled around with this?)
Anyone have any thoughts on this one?
Diesel Powered is offline
Old 01-14-2008, 04:47 PM   #2 (permalink)
WildTurkey
WildTurkey's Avatar
Car: 2006 Loaded, Black 300 SRT8
Member Number: 4369
Mine developed the shake at around 75mph with the stock F1s at around 8,000 miles. I took it in for an alignment. It was clearly out of specs - so much so that the tech thought I must have hit something. I got it aligned and it fixed the vibration. Good luck getting this fixed!!
WildTurkey is offline
Old 01-15-2008, 04:21 AM   #3 (permalink)
EricG
Member Number: 6420
I'd be willing to bet that your tires are not balanced properly. I could tell you exactly where to go for a perfect balance here in Cincinnati. You need a shop with the newest Road Force Balance machine that can accomodate 20 inch tires. Good luck.
Eric
AFE II intake, 185 t-stat, BT catch can, Predator with CMR tune, resonater delete exhaust
Stock best with AFE intake only: 12.949@109.17 w/2.009 60' - 8.406 1/8 mile on 10/11/07 DA +100 Tri-State Dragway Cincinnati
With a tune: 12.649@113.98 w/1.945 60' - 8.219 1/8 mile on 5/28/08 DA +600 Muncie Indiana Dragway
EricG is offline
Old 01-15-2008, 10:23 AM   #4 (permalink)
ATX3HUNNID
ATX3HUNNID's Avatar
Car: 2007 CHRYSLER 300
Member Number: 13249
I still get a vibration at 75 on my stockies, I took it in once and they said I had a bent wheel. got it replaced and a few weeks later it started up again. tires are balanced. Ive read a lot on this with these cars
ATX3HUNNID is offline
Old 01-15-2008, 01:45 PM   #5 (permalink)
Diesel Powered
Took the car to another shop today, and had them rebalance the tires using a road force machine. The balance done by the original shop was WAY off (ie 3 oz's) and this was performed on all 4 tires.
Now I am riding on butter, got on the toll road today at no wobble at 75 and no wobble at 140 either!
Old 01-15-2008, 01:47 PM   #6 (permalink)
ATX3HUNNID
ATX3HUNNID's Avatar
road force machine? I'll look into that. congrats!
Old 01-15-2008, 02:34 PM   #7 (permalink)
Diesel Powered
Hunter GSP9700 Wheel Vibration Control System
This was the link I used to find the closest one to me. Good luck, and I hope it works for you as well.
Old 01-15-2008, 09:09 PM   #8 (permalink)
WildTurkey
WildTurkey's Avatar
Member Number: 4369
Great News...glad you found a fix
Old 01-20-2008, 10:26 AM   #9 (permalink)
claude9039u
Car: 06 Dodge Magnum
Member Number: 15639
Get them balanced correcty. I went thru this and trust me 2 dealers later the bottom line it was the balancing of the tires. Have the dealer do it.
claude9039u is offline
Old 01-20-2008, 10:50 AM   #10 (permalink)
Maistro69
Maistro69's Avatar
Car: 2006 Chrysler 300 SRT8
Member Number: 1937
I had the same problem. They did a static balance instead of dynamic. The front driver side tire was 1.5 oz out and made it shake like crazy. I was very disappointed to have paid nearly a grand for tires and then have to pay somebody else to balance them correctly.
Performance mods to date:
PPP Stage 2 Heads
Southern Hot Rod Special grind camshaft
American Racing Longtubes
DMH Cutouts
DSS 1000HP Halfshafts
3200 PI Stall converter
Billy Boat Exhaust
Cat delete
Resonator delete
Diablo
Strut bar
Toyo Proxes 4's
Grip Grille
Mods on order:
Bullet Twin Screw
Drag Chute "Cause this Gorilla F'ing Screams"
Non performance mods:
Too many to list"
Maistro69 is offline
