Old 05-02-2009, 10:07 AM   #1 (permalink)
Points: 4,295, Level: 1 Points: 4,295, Level: 1 Points: 4,295, Level: 1
tx_bandit's Avatar
Car: 2006 Chrsyler 300C SRT8
Member Number: 15722
Trader Rating: (4)
275/40/20 Toyo Proxes - spacer?
I see several members are running 273/40/20 tires on all four corners and would like to do the same om my SRT8. Some posts talk about running a 3mm spacer on the front for clearance. Is a spacer required on the SRT8 or just the non-brembo brake 300 models? Thanks.
EDIT: I should mention that I want to run these on original factory 20 inch SRT rims.
425 h.p., 420 ft/lbs torque, forged wheels and brembos
and thats before any mods!
tx_bandit is online now
Old 05-02-2009, 10:09 AM   #2 (permalink)
Points: 3,236, Level: 1 Points: 3,236, Level: 1 Points: 3,236, Level: 1
mtroute's Avatar
Car: 2006 Chrysler 300c Cool Vanilla
Member Number: 10740
I have only seen it used on 300C's running SRT8 OEM wheels. The Factory Reproductions SRT8 wheels do not require the spacer. It all depends on the offset of the wheels you are using.
2006 300C
Predator [S]93[/S]91CAI Tuned
K&N CAI
Factory Reproductions 20" SRT Wheels
275/40 20 Hankook Ventus ST RH06
mtroute is offline
Old 05-02-2009, 10:55 AM   #3 (permalink)
tx_bandit's Avatar
Trader Rating: (4)
Thanks MTROUTE, I've added the fact that I am running stock srt8 rims to the question.
Old 05-02-2009, 11:09 AM   #4 (permalink)
Points: 1,972, Level: 1 Points: 1,972, Level: 1 Points: 1,972, Level: 1
SRT_3Hundy's Avatar
Member Number: 20410
Im curious about this myself. Ive never heard of needing a spacer but i should ask now before i get myself into trouble.
I have an 06 300C SRT8 with Toyo 255/45's all around. I want to change to Toyo 275/40's myself on my stock SRT wheels. Will i need the spacer and if so, where can i find it and how much?
Will it make the front wheels stick out farther than the rear?
Not trying to jack the thread. Im hoping this will help tx_bandit as well...
2006 Silver 300C SRT-8
1996 CE LT4 Vette
2006 Kawasaki ZX6R 636
SRT_3Hundy is offline
Old 05-03-2009, 05:44 AM   #5 (permalink)
Performance Moderator
Points: 15,340, Level: 1 Points: 15,340, Level: 1 Points: 15,340, Level: 1
Car: 06 Deluxe! CSRT8
Member Number: 3650
not
no spacer is needed for my car. I ran 275/40/20 for 3 days to test tire sizes and never had any contact of any kind.
Many members here run them on all 4 corners with stock SRT8 rims. But on an SRT8 they fit just fine.
J. William Fulbright
Steve
06 300C SRT8 all stock
stevesrt8 is offline
Old 05-03-2009, 09:35 AM   #6 (permalink)
tx_bandit's Avatar
Trader Rating: (4)
Thank you, Sir!
Old 05-03-2009, 11:45 AM   #7 (permalink)
Points: 2,190, Level: 1 Points: 2,190, Level: 1 Points: 2,190, Level: 1
Russell's Avatar
Car: 2006 chrysler 300c srt8
Member Number: 19380
i am running 275 x 40 on all four corners on stock SRT rims with no issues at all and plenty of clearance all round no worries
22" Vossen 5" lips
Rolled arches
Corsa catback
AFE11 CAI
T Stat mod
QTP cut outs
King springs
Russell is offline
Old 05-05-2009, 10:54 AM   #8 (permalink)
SRT_3Hundy's Avatar
Thanks for the info man!
Old 05-06-2009, 09:56 AM   #9 (permalink)
Points: 2,632, Level: 1 Points: 2,632, Level: 1 Points: 2,632, Level: 1
Car: 2006 Chrysler 300c SRT8
Member Number: 7012
Have never heard of a Spacer required for stock SRT rims.
I Have run 275/40/20 on stock SRT8 Rims for over 2 years now and havent had a problem.
They don't rub, they fit well and they fill out the guard for that tougher 'fatter' look.
Also i found the tyres last a litle longer as they can be fully rotated.
Konvict is offline
Old 05-06-2009, 10:12 AM   #10 (permalink)
mtroute's Avatar
People who are putting stock SRT wheels on a 5.7 "C" need the spacers.
mtroute is offline
