Old 11-08-2009, 07:20 AM   #1 (permalink)
Points: 3,075, Level: 1 Points: 3,075, Level: 1 Points: 3,075, Level: 1
Julius's Avatar
Car: 2006 Chrysler 300C SRT-8 Silver Steel
Member Number: 5361
Running with different tire brands
I currently have 18K on the car. Last year I bought a rear set of RSA's to replace the RSA's that came with the car. Since then I got the Predator and now I can't keep the rear planted at at all, especially since the weather has cooled a bit. Changing lanes between the 1-2 shift is interesting to say the least
I would like to move the newer RSA's up front and replace the rears with Toyo Proxes 4 275 40R20's.
The rear RSA's have 3 to 4K on them and I would like to get some more miles out of them before I toss 'em.
Any downside to this plan other than just the look of two sets of tires?
Thanks for any help here.
Julius
2006 300C SRT-8
<Silver Steel Super Hemi>
Julius is offline
Old 11-08-2009, 07:28 AM   #2 (permalink)
Points: 7,422, Level: 1 Points: 7,422, Level: 1 Points: 7,422, Level: 1
EXTREME-SRT8's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 3581
I don't know of any down side. I know a lot of people that run diff brand tires. I'm running nitto up front and goodyear out back.
AirHammer CAI - Corsa Catback - Magnaflow Catted Midpipes - 5% Llumar Tints - Tinted LED Tails
Billet Tech Goodies - XenonDepot 8000K Lows - 3B 12000K Fogs - Diablo Sport Predator
JT and NoESP Auto Fan Mod - Eibach ProKit - Stealth Auto - NavHack
12.96 @ 111.83
EXTREME-SRT8 is offline
Old 11-08-2009, 07:39 AM   #3 (permalink)
Points: 90,045, Level: 1 Points: 90,045, Level: 1 Points: 90,045, Level: 1
Activity: 44% Activity: 44% Activity: 44%
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Trader Rating: (6)
Found this on TireRack.
Makes sense I guess.
EDIT: Apparently AutoGuide doesn't like Tire Rack???
As a general rule, tires should not be mixed on any vehicle unless specified as acceptable by the tire or vehicle manufacturer. Drivers should avoid mixing tires with different tread patterns, internal constructions or sizes, and use identical tires on all of their vehicle's wheel positions in order to maintain the best control and stability. Additionally, drivers should never mix winter tires with all-season/summer tires, or mix run-flat tires with non-run-flat tires.
This is one of the reasons that it is desirable to have all of a vehicle's tires wear out at the same time. It's confirmation that the vehicle design, driving conditions and maintenance practices worked in unison to equalize tire wear and performance. It also lets drivers know they got their money's worth out of the current tires and allows them to choose a set of replacements that will either maintain the Original Equipment (O.E.) tires' capabilities, or help tune the vehicle's qualities to even better suit their needs.
Unfortunately wearing out all tires at the same time isn't always possible. Sometimes vehicle design, the use of differently sized tires on front and rear axles, insufficient maintenance and/or driving conditions conspire to prevent it from happening. If a vehicle's tires don't all wear out at the same time, drivers are typically forced to decide whether they should purchase a new set of tires (forfeiting the worth of the two tires not fully worn out) or just a pair of replacements. While purchasing a new set of tires is best because it will maintain the handling balance engineered into the vehicle while restoring poor weather traction, it is also more expensive. And while purchasing a pair of replacement tires reduces immediate expense, it brings with it the options of choosing exact, equivalent or alternative tires.
Of the three, the best choice is to select the exact tire currently on the vehicle. This assures that the tire's physical dimensions, internal construction, tread design and tread compound are equal to the tires being replaced.
The second option is to choose equivalent tires from the same tire performance category that share the same speed rating, handling and traction characteristics of the original tires. While this isn't as desirable as selecting the exact tire currently on the vehicle, it can become necessary when the original tires are no longer available.
The third option, choosing alternative tires, should only be considered as a temporary solution in an emergency situation. Using alternative tires from different tire performance categories, with alternate sizes or different speed ratings can unbalance the vehicle's handling in poor weather or when pushed to the limit in an emergency.
Because tires play such an important role in every vehicle's comfort qualities and handling capabilities, it is always best to drive on tires that are identical in every detail, including tire brand, model, size and remaining tread depth. Anything else involves some type of compromise.
Bernie
Rambit is offline
Old 11-08-2009, 08:09 AM   #4 (permalink)
Points: 25,469, Level: 1 Points: 25,469, Level: 1 Points: 25,469, Level: 1
Activity: 89% Activity: 89% Activity: 89%
GoofyTimL's Avatar
Member Number: 3755
Trader Rating: (4)
The only downside I see is inferior grip of the RSAs for wet conditions, or really any aggressive cornering you might be tempted to do in otherwise ideal conditions. But as long as you drive knowing where your weak point is... No problem should result.
This is similar to my situation of running Blizzaks on the rear and new TP4s on the front of the MSRT8 this winter. Not the idal, but manageable because I know the TPs are the lesser gripping tires in adverse conditions and will drive appropriately.
GoofyTimL is online now
Old 11-11-2009, 07:02 PM   #5 (permalink)
Julius's Avatar
Member Number: 5361
Thanks for the responses.
Knowing the shortcomings of the RSA's, I wouldn't have a problem with putting Toyo's in the back for now, then moving them up front next summer and putting new Toyo's in the rear.
I really don't drive the front's that hard and I don't take her out in the rain for the most part.
I would like to tame the beast from a start and on the 1-2 shift that can get quite interesting when it hits between a lane change (Predator induced).
Julius is offline
Old 11-11-2009, 07:14 PM   #6 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
I had the RSA's up front and Hoonkooks out back and my ESP thru fits, I had no traction on corners and chripped at every launch from a red light no matter how light of throttle I gave it..
but especially in corners, the back end was all over the place.
I replaced the front RSA's with matching Hoonkooks and the problem was gone immediately..
Mr. iNCREDIBLE is offline
Old 11-12-2009, 10:44 AM   #7 (permalink)
Points: 7,663, Level: 1 Points: 7,663, Level: 1 Points: 7,663, Level: 1
marnepup's Avatar
Member Number: 2139
mixing tires is bad ju-ju...
Dream upgrade package (not ones I already have!!):
STS remote twin turbos
Quaife LSD
level 5 halfshafts
southern hotrod (800hp) transmission
Magnaflow high-flows
Corsa catback
AFE Stage II CAI
PP TC
...of course, I don't know if they make tires for that!
marnepup is online now
