Old 10-04-2005, 07:11 AM   #11 (permalink)
Member Number: 2861
Originally Posted by PixelPusher
Do you guys have a part # on the bolts? I would like to get them and have them installed when I get my car re-aligned after the new K&W's settle in.
Yup- Got Burned. It's got to be my friendly attitude!! Nice job Patriot!!
Fish220sr is offline
Old 10-05-2005, 08:45 AM   #12 (permalink)
300degree's Avatar
Member Number: 3559
I don't get it. Are these custom camber bolts for lowered suspension? If not, why would you get new ones?
Someone needs to manufacture a camber correction kit for the front and rear; otherwise, tire replacement is going to become an expensive routine.
300degree is offline
Old 10-05-2005, 01:01 PM   #13 (permalink)
mvpatriot's Avatar
Member Number: 2168
PART NO. #5134117AA
DESCRIP. BOLT-CAMBER A
Only reason you need this is if you are lowered or having allingment/camber issues. Or you can rotate every 3K miles.
This bolt will correct the camber by only 3-5 degrees I believe.
Something is better than nothing.
2006 300C Brilliant Black
-Black Devino Duel 22x9.5 +18 offset
-Universal Air Suspension/Dakota Digital Gauge
-BCool Mesh Grille
-V.I.P. Headlight Covers
-Nu Image Diamond Gauges/Clock (yep thats me in the RIDES ad)
-Satin Nickel NYC Dash Kit
-Autovation Aluminum 4pc. Pedal Kit
-Smoked Tail Lights and Side Markers
-Viper Pager
-20% Tint
mvpatriot is offline
Old 10-05-2005, 08:29 PM   #14 (permalink)
FastEd's Avatar
Member Number: 3232
Send a message via AIM to FastEd
Originally Posted by mvpatriot
PART NO. #5134117AA
I took my car into the dealer today for the R/H drift TSB (warranty revised alignment specs), it is currently not lowered.
When I picked it up it up this evening I talked to the Service Writer about alignment after lowering the car and he said it was not a problem because the new bolts were installed during the TSB.
I hope this is true... hotchkis springs and sway bars arrived UPS today
FastEd is offline
Old 10-06-2005, 12:31 AM   #15 (permalink)
PixelPusher's Avatar
Car: 2005 Sweet 300c
Member Number: 201
PART NO. #5134117AA
thx for the part #.. the drop I have set with the new K&W coil overs is not as severe as with the eibach pro-kit so hopefully the bolts will be enough to do the trick when I get the alignment done next week.
2005 300C Brilliant Black (click for pics)
Loaded... and the car drinks a lot too.
PixelPusher is offline
Old 10-06-2005, 12:46 AM   #16 (permalink)
Administrator
HEMEEE's Avatar
Car: '07 Chrysler 300C SRT8
Member Number: 664
Congrats on the Hotchkis setup, you're gonna love it! Be sure to post pics when you've done the install.
Sorry Jared, back on topic
Linda... * More Pics *
HEMEEE is online now
Old 10-06-2005, 12:54 AM   #17 (permalink)
Scarbs's Avatar
Car: 2005 Chrysler 300C Deep Lava Red 1 of 1641
Member Number: 446
Hold on. our saying that the TSB to fix the right pull will also work on my new aligment with the pro-kit!
Eric
Black Cherri 1 of 1641
Bad Monkey
Windy City Swag
Scarbs is offline
Old 10-06-2005, 01:10 AM   #18 (permalink)
mvpatriot's Avatar
Member Number: 2168
only if they install the camber bolts during the TSB
-BCool Mesh Grille
-Viper Pager
-20% Tint
Old 10-06-2005, 01:26 AM   #19 (permalink)
300degree's Avatar
Member Number: 3559
Sorry, I'm a little skeptical that camber bolts alone will fix camber problems from a lowered suspension.
Quote: "This bolt will correct the camber by only 3-5 degrees I believe."
No freakin' way dood! 3-5 degrees of camber is HUGE w/o adjustable arms/plates. No way bolts can give you that kind of adjustability.
Show me the before and after alignment readings when the bolts are installed on a lowered suspension!
Old 10-06-2005, 11:20 AM   #20 (permalink)
Scarbs's Avatar
Member Number: 446
Wouldnt you say that if you had the right pull fixed you got the bolt?
I'll let you know when i get my aligiment done.
Eric
Bad Monkey
Windy City Swag
Scarbs is offline
