I have another question maybe zilla can comment on. Do you think that the KW Variant 1 would be fine to go w/ instead of the Variant 2? I feel that if I go w/ the Variant 2, I would always be at the shop trying to have them adjust the ride and never be satisfied. Can I trust KW's engineers w/ the way they have set the ride quality on the Variant 1?
The main thing I am looking for is a 1.8-2" drop w/ great ride quality and handling. Plus, I'd love to save a couple hundred a bucks while I'm at it!
Mike I will reply to this when I am a bit more focussed. I will give you some reasons to use the adjustables and you can decide if it's worth it then.
Zilla
Speed: " It's really about judgement and intelligence; so long as your brain can go faster than your going at any time, you're all right, and it isn't fast." - L J K Setright
When I asked about the discrepancy between the measurements I posted yesterday and those originally reported for my car, Hotchkis Performance elaborated on the earlier "due to tolerances" comment as follows:
"Most steel manufactuers have a tolerance of 0.030 in outside diameter".
I have Placed all measurements in a single post for ease of review:
If I missed, or misstated any of the facts below, please PM me so I can make a correction.
--------------------------------------------------------------------------------------------------- 8/05 Per Hotchkis during my install-
based on the sway bars from my car:
= stock C front sway Ø 1.056
= stock C rear sway Ø .559
=HP Front Sway: Ø 1.375" - 30% stiffer than stock 300C
=HP Rear Sway: Ø .750" - 150% stiffer than stock 300C
11/22 Per Hotchkis when asked for SRT8 meas. confirmation-
based on re-measure of stock sway bars on hand at the shop:
300C & SRT8 are the same @
=Front: 1.055
=Rear: 0.593
11/22 Per 'zilla's measurements-
based on his own SRT8:
- remember I was fumbling in the dark; like a 16 year old.
LMAO!!!
Zilla
Thanks zilla, whenever you get a chance.......Anyone out there who is considering the KWs thinking about going w/ the Variant 1s to save a couple hundred?
Also zilla, when you get a chance, can you comment as to why they would make them hollow as opposed to solid? Seems like solid would be the way to go......
From what I understand, size matters more than density. The hollow ones are plenty strong and are lighter for decreased unsprung weight. I think the new ZO6 uses hollow bars.
__________________ 2006 300c SRT-8 (wife's daily driver) Option I, II, sunroof, Kicker, Rear DVD
Hi again Mike
If you do not use should car for actual competition, or driving where you explore the absolute limits of your roadholding, then the lack of adjustability on the Variant 1 should not affect you. There may be disadvanrages when other mods that affect the suspension are added - example different swaybays. I'll explain why below.
If however you like to tweak the car to get the car optimum for you, then there is significant benefit to the adjustability on the Variant 2, (which is on the rebound stroke only - not adjustable on compression). It primarily, controls pitch and roll of the vehicle, especially in the low speed damping range which directly influences handling and comfort. It can not only give you a less floaty ride, in addition the front or rear shocks can be set at different stiffness settings to affect the oversteer/understeer of the car. The roll stiffness of the car can be increased, differentially front to rear, to add to whatever flatness on cornering and better tire contact, the sway (anti-roll) bars provide. Additionally, as the shocks wear they can be adjusted stiffer to compensate for loss of damping, and the summer/winter variantions in fluid viscosity due to temperature variation can be compensated for.
Human nature being what it is the tendancy on a road car is the spend time on the initial set up, and then leave it until you notice that someting feels out of whack or could be improved.
Stiffness is function of the outside diameter of the bar, so the center material of the bar contributes little or nothing to the twisting stiffness. A tubular and solid bar will work identically, provided the are tubes of adequate wall thickness and material, but it will be maybe 40-50% lighter.
Zilla
...Once you lower and firm up spring rates, the limits of the OEM sways become really noticeable.
If I go coilovers, I will also add the Hotchkis swaybar set.
I, too, am waiting to see the Mopar coilovers before making a decision on shocks/springs. However, the current tbyrne GB on the Hotchkiss sway bars makes it extremely tempting to me to install the anti-sways now.
Any particular reason you're not moving ahead with the sway bars at this time, NR?
goddardzilla - Our thoughts and prayers are with you and your wife at this difficult time.
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
A couple, Meister. First, we have 6" of snow and are in survival driving mode until the spring. Secondly, I want to do all the suspension work at the same time - lots of labour hours involved. I would prefer coilovers to just a spring swap. However, Tom's deal on the Hotchkis stuff is really tempting.
There is one other consideration. I want a dedicated race car - something affordable, just for summer weekend circuit racing. I am looking at the vintage series as well as the mini-legends.
