Old 12-31-2005, 02:18 PM   #11 (permalink)
smoove7410's Avatar
Car: 2006 Chrysler 300c
Member Number: 50
Originally Posted by mikew2069
no, no recommended settings....Fatchance, you aren't using the eibach springs are you?
He had the eibach springs before he got the kw's, so no, he is not using the eibach springs.
smoove7410 is online now
Old 12-31-2005, 04:13 PM   #12 (permalink)
fatchance's Avatar
Car: 05 Silver 300c
Member Number: 422
How do you have your dampening set front and back?...also, where is the back knobs? I didn't ask before I left the shop yesterday....
I turned mine up one. But you need the black knob to do it. Call the shop.
fatchance is offline
Old 12-31-2005, 07:09 PM   #13 (permalink)
mikew2069's Avatar
Car: 2005 C 300
Member Number: 1106
They showed me how to adjust the front... By turning yours up one, do you mean stiffer?
mikew2069 is offline
Old 12-31-2005, 07:34 PM   #14 (permalink)
lmhoward's Avatar
Car: 2005 c 300
Member Number: 2497
I'm paying close attention fatchance. For me your a 300c pioneer, love all your mods. I imagine when my KW package arrives the instructions will provide many answers. Any enlightenment you can give will be highly valued by us slowpokes
lmhoward is offline
Old 12-31-2005, 11:43 PM   #15 (permalink)
3SRT4ME's Avatar
Car: 2006 SRT8 300C
Member Number: 554
I dropped the rear of my 3SRT8 approximately 20 mm and the front around 30 mm. And I have the rear dampening turned one full turn and the front two full turns.
Definitely tighter and smoother, yet not at all overly harsh or firm.
Use to be "300C4ME"
Member No. 52
3SRT4ME is offline
Old 01-02-2006, 09:54 AM   #16 (permalink)
mikew2069's Avatar
Car: 2005 C 300
Member Number: 1106
When you say you have the dampening turned one full turn, do you mean that you started at the negative and turned one full turn to the positive?
I will be getting my alignment done on Wed and I will also start adjusting the front starting all the way negative at one full turn a day......
Will post in a couple days w/ my results.....
Old 01-02-2006, 10:28 AM   #17 (permalink)
Member Number: 232
Here is a link to the KW install instructions, with some recommendations.
Hope this helps. After they are installed, you can apparently adjust one wheel at a time on a tire jack. No need to put it on a ramp.
http://www.kw-suspension.com/en/30_P...ilover&zeile=4
http://www.kw-gmbh.de/kw_upload/Einbau/eah68627016.pdf
http://www.kw-gmbh.de/kw_upload/Einbau/ea68577524.pdf
joey is offline
Old 01-02-2006, 10:40 AM   #18 (permalink)
mikew2069's Avatar
Car: 2005 C 300
Member Number: 1106
Good info.
Thanks
BTW, does anyone know where the dampning adjuster is on the rear?
Old 01-02-2006, 08:12 PM   #19 (permalink)
3SRT4ME's Avatar
Car: 2006 SRT8 300C
Member Number: 554
Good info.
Thanks
Right beneath the trunk liner "humps" on each side of the trunk. To access the dampening knob, fold the rear seats down, pull the plastic push pin that holds the trunk liner on each side, pull the liner back and reach in to adjust the knob.
Use to be "300C4ME"
Member No. 52
3SRT4ME is offline
Old 01-02-2006, 09:36 PM   #20 (permalink)
mikew2069's Avatar
Car: 2005 C 300
Member Number: 1106
Ah, much appreciated....I remember seeing them when installing the dynamat.
