Old 07-13-2008, 10:33 AM   #131 (permalink)
Points: 4,944, Level: 1 Points: 4,944, Level: 1 Points: 4,944, Level: 1
Brick Tamland's Avatar
Car: 2006 Chrysler Black 300C
Member Number: 8510
The prevailing theory is Mopar coilovers are manufactured by KW.
The Mopar coilovers are essentially the same as the KW v1.s
The difference between KW v1's and v2's is the damper rebound can be adjusted on the V2's. If you like very little rebound/bounce you can tighten the V2's down with an adjuster knob.
Below is a pic of the adjuster knob. The knob is placed on top of each strut/shock. If you have an extra $300 or so, get the V2's. I have found after 20k miles the struts/shocks have become a little more bouncier/looser over time. With the V2's you can tighten up the ride to your liking.
http://www.kw-gmbh.de/kw_upload/Einbau/ea68577504.pdf
So Joey, just so I understand this correctly, the V1 and V2 are not able to adjust the right height, or they can both adjust the ride height?
MY WISHLIST:
[ ]22" Foose Impressions w/ Pirelli Scorpions
[X]Zoomers
[X]AFE Stage 2
[X]Superchip Flashpaq
[ ]Autolumination 300c SuperWhite Overhaul Set
[X]Tinted Rear LED Tail Lights
[ ]Hotchkis Sport Sway Bar Set
[ ]U.A.S. UNIVERSAL AIR SUSPENSION
[X]GTS Chrysler 300C/SRT8 Driving Light Covers
[ ]TommyZ Deep Dish Grill
[X]Alpine IVAW-200 DDin w/ integrated Blackbird
[X]Low Temp TStat (180)
[X]HHP Hi-Flow Cats
Brick's 300c -
http://www.cardomain.com/ride/2612006
Brick Tamland is offline
Old 07-13-2008, 10:56 AM   #132 (permalink)
Points: 2,408, Level: 1 Points: 2,408, Level: 1 Points: 2,408, Level: 1
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
It is not just the damper that wears. The coil over coils wear and so do the other springs in your suspension -- the black rubber springs that we refer to as bushes. The bushes are an active part of the suspension offering both bound and rebound spring and resistance. As the bushes wear the suspension becomes softer.
When you lower a car it is a best practice to loosen all the rotational bush bolts on the lift with the wheels at full droop. With everything loose, drive the car around the shop parking lot or you street very SLOWLY to settle the bush to the new ride height. On the alignment rack rail style lift tighten all the bolts with the weight of the car on the wheels. This times the bushes to the new ride height. It also allows preserves the life of the bushes.
Pete Basica
www.PeddersUSA.com
JusticePete is offline
Old 07-13-2008, 11:14 AM   #133 (permalink)
Member Number: 232
The ride height can be adjusted on both the V1 and V2's. Only the V2's allow you to adjust the damper rebound.
joey is online now
Old 07-13-2008, 11:29 AM   #134 (permalink)
Member Number: 232
I know the shop that installed my KW's didn't follow your recommendation. These are pics of my KW bushings. They look good to me. Do you see a problem? Or is there another way to check the bushings?
joey is online now
Old 07-13-2008, 03:11 PM   #135 (permalink)
Member Number: 8510
So, with the damper rebound not an issue for me, should I go with Hotchki's sways and the mopar version of the V1;s?
Old 07-13-2008, 03:31 PM   #136 (permalink)
Member Number: 232
Yes, the Mopar coilovers and KW v1's provide the same functionality.
joey is online now
Old 07-13-2008, 04:14 PM   #137 (permalink)
Points: 17,342, Level: 1 Points: 17,342, Level: 1 Points: 17,342, Level: 1
Meister's Avatar
Member Number: 942
But, last I checked Brick, IIRC the KW V1s are typically priced less than Mopar coilovers.
EDIT: 'Good news is you'll find that both flavors are available through supporting vendors here - you just won't find both flavors at the same store.
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
Last edited by Meister : 07-13-2008 at 05:34 PM. Reason: Add info re. supporting vendors
Meister is offline
Old 07-13-2008, 04:58 PM   #138 (permalink)
Member Number: 8510
Thanks Meister,
I assumed the Mopars would have been cheaper. I will do some hunting. Anyone know of a good KW V1+ Hotchki's sway package? Maybe one of the supporting vendors...
Old 07-13-2008, 05:56 PM   #139 (permalink)
Meister's Avatar
Member Number: 942
Thumbs up
...When you lower a car it is a best practice to loosen all the rotational bush bolts on the lift with the wheels at full droop. With everything loose, drive the car around the shop parking lot or you street very SLOWLY to settle the bush to the new ride height. On the alignment rack rail style lift tighten all the bolts with the weight of the car on the wheels. This times the bushes to the new ride height. It also allows preserves the life of the bushes.
Man, that's interesting! And it's truly quite impressive that Pedders goes to such lengths to make sure the system is "shook out", loaded, while everything's loose, and then snugged with full weight still on the suspension.
I'd be surprised if even the factory does that. I've sure never seen, or even heard of, competing manufacturers performing the loaded "shake out" (my term).
Pete, most impressive, sir.
But I'll have to "bean" you elsewhere.
Meister is offline
Old 07-14-2008, 06:05 PM   #140 (permalink)
I have one friend left in the LX world, actually two but I don't know that I can count Mike as I pay him.
