Old 11-20-2008, 08:12 AM   #161 (permalink)
Points: 6,776, Level: 1 Points: 6,776, Level: 1 Points: 6,776, Level: 1
jaydee's Avatar
Car: 2006 AWD 300C
Member Number: 1474
Joey,
your "fix" is interesting. This suggests to me that KW should pay you big time for diagnosing a problem and they should be sending bushings and stronger springs to everyone who has sunk substantial money on these products.
Jay
jaydee is offline
Old 11-30-2008, 07:19 PM   #162 (permalink)
Points: 2,408, Level: 1 Points: 2,408, Level: 1 Points: 2,408, Level: 1
JusticePete's Avatar
Car: 2005 Chrysler Pacifica
Member Number: 10746
Not sure if you saw my thread, but I found the fix to my popping.
The upper two spring coils were/are torquing/banging on each other.
Inserting rubber between the two springs stopped the noise.
This is known as coil pop. The coils are supposed to stay firmly in contact as keeper coils. Sometimes, the roll and pop. Your rubber hose fix is the same as OE coil wrap. Well Done!
Pete Basica
www.PeddersUSA.com
JusticePete is offline
Old 12-01-2008, 12:33 AM   #163 (permalink)
Points: 1,518, Level: 1 Points: 1,518, Level: 1 Points: 1,518, Level: 1
Car: 2006 Chrysler 300C AWD
Member Number: 11751
As I posted on 9-22 the KW's have been nothing but major problems and a money pit. It annoys me further that I've spent a total of $4K already, which includes the KW kit, labor t install them and paying for labor and parts in a attempt to clear up all the problems. Non the less these problems still exist. The shop that installed the kit (KW Authorized Shop) also had to wait for weeks to receive the new rear bushings and of course I was charged to dismount and remount everything and then again charged to dismount and remount. The popping noise in the front still exists and no one seems to know what the problem is, not even the KW Authorized Shop. I've given up. I will be remounting the original shocks and springs. For the price of $2K the KW's have certainly not lived up to my expectations and I do not recommend them (at least for AWD). Joey that is very interesting that the rubber between the coils cleared up your problem. I must commend you on an excellent find and wonder why KW didn't come up with it. I will definitely try your recommendation and hope it works. That will be my last attempt to rectify the problem on my car. Then it's back to the originals. I will post after I do it.
Top40 is offline
Old 12-01-2008, 06:42 AM   #164 (permalink)
Points: 127,841, Level: 1 Points: 127,841, Level: 1 Points: 127,841, Level: 1
Member Number: 232
It was also very time consuming and costly for me to find a solution.
If you try the rubber inserts, you don't need as much rubber as shown in my pic. The rubber doesn't encircle the entire coal. The only functional part of the insert is the piece in between the coal. See the attached pic. I wasn't sure how the rubber was going to fit, so I had cut a chunk out of the rubber tube so the shape was a C. Most of the rubber shown in the pic is just hanging there and not helping. The weight of the car on the spring is holding the rubber inplace.
Just jack the car up about 1 to 2 inches until the spring opens up enough to insert the rubber. The wheels won't need to be off the ground and you don't need to take the wheels off. Just reach in and stick the rubber inserts in between the coals. The whole process takes 5 to 10 minutes.
If I didn't buy the wireless chassis ears I doubt I would have ever found this solution. The chassis ears narrowed the popping down to the coilover area. From what I could tell, the chassis ears had ruled out tie rods, steering rack, tension strut, and upper and lower control arms, ball joints, and brakes.
I was originally certain it was the endlinks, which I replaced. When that didn't fix the popping I posted the Youtube video of the noise amplified with the wireless chassis ears. Although I doubted the springs/struts were the cause of the noise, I called Tom Edge and he watched the video on Youtube.
He immediately said it was my upper strut mount bearing. At the time I didn't know our strut mounts do not have bearings. But when I sprayed the upper strut mount area and upper springs with silicone lubricant in hopes of lubricating the bearing the popping stopped for 2 days, but would return after the lubricant dissipated. So I was convinced it was the strut mount and bought one.
After receiving the strut mount I find out there is no bearing or moving part and I am really stumped why the silicone lubricant stopped the popping. But I install the upper strut mount anyway, and the popping doesn't stop.
So I continue to spray the strut mount and upper springs with silicone lubricant and the popping continues to stop for 2 days. I then came up with the idea of the rubber inserts.
I called Tom again and told him of my fix and he seemed skeptical, or maybe stumped. He said he had never seen this problem before with KW springs. Later I find out the noise/problem is called coilover "binding". I did some googling on "binding" and it is a known problem.
The true fix is a new spring. But I have a set of relatively new KW springs in the garage that KW sent me 1.5 years ago for another problem. So I didn't ask Tom to send me new springs. I will see how long this rubber insert fix lasts. Someday I may pay the $50 labor to have the springs swapped out.
joey is online now
Old 12-01-2008, 11:28 AM   #165 (permalink)
Points: 2,329, Level: 1 Points: 2,329, Level: 1 Points: 2,329, Level: 1
Moebius44's Avatar
Car: 2005 Dodge Magnum
Member Number: 10921
I would really like to hear the sound you recorded to compare to my "noise", can you point me to the URL please...
HEMISSARY
Moebius44 is offline
Old 12-01-2008, 01:27 PM   #166 (permalink)
Member Number: 232
Here is the vid (also see post #158 on previous page).
When watching the first video, the popping is heard at the following seconds into the vid -. Ignore the hissing sound.
6 seconds, 8, 10, 18, 24, 31, 34, 36, 39, 46
YouTube - Chrysler 300c front suspension popping/clunking noise
joey is online now
Old 12-01-2008, 03:50 PM   #167 (permalink)
Joey excellent find...you may have solved an issue that lot of people may be having. I haven't put the rubber inserts around the spring yet but will this weekend. KW should pay you for finding the fix. Now they should upgrade their product knowing one of the problems that exist with their coilover kit. After trying upper strut mounts (twice), tie rod ends, upper and lower control arms and lots of time I hope this is my solution. I will post after complete. Thanks again Joey!
Top40 is offline
Old 12-01-2008, 04:12 PM   #168 (permalink)
Member Number: 232
That would be cool if the rubber inserts fixed your problem. You already eliminated a few other possibilities, so this may be your fix too.
If you have an oil catch can, you probably have some extra hose line laying around. That is what I used for the insert.
joey is online now
Old 02-22-2009, 06:22 PM   #169 (permalink)
Points: 20,553, Level: 1 Points: 20,553, Level: 1 Points: 20,553, Level: 1
smoove7410's Avatar
Car: 2006 Chrysler 300c
Member Number: 50
I just had the KW2s installed. I have the clunk when hitting bumps in the right rear. Is this what everyone had?
smoove7410 is offline
Old 02-22-2009, 06:31 PM   #170 (permalink)
Member Number: 232
See the pics in post number #144. If you have a bad bushing the shock could be sliding off the bushing and banging against the cradle.
But I would be surprised brand new KW's would have bushing failure.
If the bushings look OK, then check to make sure all the bolts were tightened to spec.
KW V2 impressions and settings
joey is online now
