Old 01-30-2006, 12:26 PM   #1 (permalink)
E55 KEV's Avatar
Member Number: 10
What Springs for 1" or less drop on 300C?
Can the SRT8 springs be used on the 300C? The Mopar springs offer more drop than I want. The SRT8 is 5.1 inches off the ground and that is enough for me.
E55 KEV is offline
Old 01-30-2006, 12:49 PM   #2 (permalink)
Administrator
HEMEEE's Avatar
Car: '07 Chrysler 300C SRT8
Member Number: 664
Kev, don't know the answer to your ? about the SRT springs, but my C was the test mule for Hotchkis Performance R&D on springs and swaybars. Their springs are rated at 1.25" but mine was a 1" drop in front and .78" rear... looks and drives great, IMO. Pics and info here
Linda... * More Pics *
HEMEEE is online now
Old 01-30-2006, 12:55 PM   #3 (permalink)
goddardzilla's Avatar
Car: 2005 Hey baby get into my big black SRT8
Member Number: 924
I am certain that the front SRT8 springs will be no problem.
The rears may not be correctly spring-rated. The reason for this is that the Nivomat shocks used in the SRT8 have a built in spring function, operated by the mechanical pumping of the shock.
Rate of rear SRT8 springs + added spring rate of Nivomat = Total rear spring rate of SRT8.
Take away the added spring rate of the Nivomats - which the stock 300c does not have, and your spring rate of the SRT8 springs alone is too low.
You might want to check out this thread.
Hotchkis Performance Springs & Sway Bars: R & D Project
Zilla
Edit Some duplication when I started typing Hemeee's answer was not there
Speed: " It's really about judgement and intelligence; so long as your brain can go faster than your going at any time, you're all right, and it isn't fast." - L J K Setright
goddardzilla is offline
Old 01-31-2006, 08:55 AM   #4 (permalink)
E55 KEV's Avatar
Member Number: 10
Thanks. Linda have you measured since the car has probably settled down now and the springs fully seated? May be something to do once you have had them for many months and miles.
E55 KEV is offline
Old 01-31-2006, 11:25 AM   #5 (permalink)
Administrator
HEMEEE's Avatar
Member Number: 664
Kev, the springs were installed in August and we re-measured again in Nov... no appreciable change. If there was one, you'd need a micrometer to gauge it.
If you'd like, I'll measure again next month, which will mark 6 mos. since install... just post a reminder.
Old 01-31-2006, 04:08 PM   #6 (permalink)
E55 KEV's Avatar
Member Number: 10
Thanks, any help is appreciated. But it looks like the Hotchkis has the lowest advertised drop.
E55 KEV is offline
Old 02-01-2006, 12:25 PM   #7 (permalink)
E55 KEV's Avatar
Member Number: 10
What if I also upgraded to the SRT dampers also? Are the front and rear shocks a direct bolt-on replacement?
E55 KEV is offline
Old 02-01-2006, 02:34 PM   #8 (permalink)
Member Number: 924
No problem, however if I was in your position and was considering that move
I would go for the coil over solution: KW Variant 2s (V2) I feel they would give you a performance edge over the stock SRT8 setup. You can set both ride height. and rebound damping to your exact liking. Lots of threads discussing the KW coilovers.
On the other hand if load-levelling is a needed feature because you carry heavy loads in your Magnum then the SRT8 rear shocks have that feature.
Zilla
Old 02-01-2006, 08:12 PM   #9 (permalink)
teahead's Avatar
Member Number: 164
As soon as I get "my wife's" car, I'm going to put on the Hotchkis SRT8 springs.
So...the stock SRT8 springs will go on sale very shortly there after. PM me if you're interested.
NEXT MOD:
9" headrests, TVNav2Go
teahead is offline
Old 02-04-2006, 12:31 AM   #10 (permalink)
Car: 2005 chrysler 300C
Member Number: 4755
Send a message via AIM to CRUCAT
from what i have seen Mopar makes a 1" drop set of springs for the 300c
CRUCAT is offline
