Old 03-16-2006, 02:17 PM   #1 (permalink)
Member Number: 5047
Air Suspension Discount for Members
Ok guys its final. The options that we are going to offer for the Forum members is as follows. Also we are not going to require any number of members to purchase at one time, its a "discount" that we are offering to everyone in the 300C Forum.
F.B.S.S. Kit as seen on our website - $2150.00
To add a set of Standard Front struts to make 100% bolt on - $300.00
To add a set of SRT8/Bilstein Front struts to make 100% bolt on - $500.00
To add Digital Gauges - $370.00
There is a very limited quanity of the SRT8 struts available. We have purchased up all the ones that the dealer has available. We are only offering these to the Forum.
Also free ground shipping anywhere in the U.S.
-Zack Ratcliff
800-864-2470
UniversalAirSuspension is online now
Old 03-20-2006, 04:19 PM   #2 (permalink)
turbohips's Avatar
Member Number: 952
For a novice car guy, what's the scale from 1-10 (10 being the hardest) for the install for the 100% bolt on kit?
Also are there going to be any special tools needed?
turbohips is offline
Old 03-20-2006, 04:26 PM   #3 (permalink)
SooNrdenL8r's Avatar
Member Number: 3664
Hey U.A., hope this discount applies to me too...i have my appointment with you guys on the 27th! i would want to add the digital gauges too!
SooNrdenL8r is offline
Old 03-20-2006, 08:12 PM   #4 (permalink)
Member Number: 5047
I like to say if you can Lower a car and wire up an amp then you can do the install.
The average install time is 20-30 man hours so you and a buddy can do it in a weekend.
TOOLS REQUIRED:
Jack & stands/Lift
Wheel wrench to remove rims
Wire Stripper
Wire Crimper
Hose Cutter
Phillips Screw Driver
Large Standard Screw Driver
Small Standard Screw Driver
Hammer
Drill
13 MM
15 MM
17 MM
18 MM
21 MM
9/16
-Zack Ratcliff
800-864-2470
Old 03-20-2006, 08:13 PM   #5 (permalink)
Member Number: 5047
Yes, you already were setup with the good-guy pricing :-)
-Zack Ratcliff
800-864-2470
Old 03-21-2006, 03:26 PM   #6 (permalink)
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
I Can't Wait!!!!!!!!!!!!!!!!!!!!!!!!!!
DUBSTER is offline
Old 03-21-2006, 06:56 PM   #7 (permalink)
turbohips's Avatar
Member Number: 952
Thank for the info. This sounds like something that I can do myself over the weekend. When my next bonus check comes in, expect a call from me. Thanks again.
Old 03-23-2006, 11:23 PM   #8 (permalink)
Blowndakrt's Avatar
Member Number: 1851
So if you order the front struts along with your kit, do you guys do the modifications to them or will the end user still have the remove that extra metal at the base of the coil?
Also, do you guy offer any control modules that allow you to have preset ride heights or remote operation? I have seen some control modules that let you have 3 different ride height presets. Would I have to purchase those from another company? Would it be compatible with your kit?
Thanks
Shawn
Blowndakrt is offline
Old 03-24-2006, 02:47 PM   #9 (permalink)
Member Number: 5047
Thanks
Shawn
If you purchase the front struts with the kit it will be all modified ready to go.
Yes you can use the dakota digital modules for the low/med/high settings. to view them you can goto http://www.dakotadigital.com/index.c...rod/prd131.htm and check them out.
As far as other systems out there. it all depends on which one it is. Most likely it will work its just a matter on how they do thier setup.
Personally i like the dakota digital setup because its reliable and we have used them in the past. The draw back is that its a pain to install (With height sensors) but it works very well no matter what weight load is inside the vehicle.
-Zack Ratcliff
800-864-2470
Old 03-25-2006, 03:37 PM   #10 (permalink)
EXTREME-SRT8's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 3581
with this kit in the trunk, does the pad go back over everything for a factory appearance??
AirHammer CAI - Corsa Catback - Magnaflow Catted Midpipes - 5% Llumar Tints - Tinted LED Tails
Billet Tech Catch Can and Int/Ext Acc. - XenonDepot 8000K - Diablo Sport Predator
JT Fan Mod and NoESP Auto Fan Mod - Motorad 4127 - Stealth Auto - NavHack
12.96 @ 107.78
EXTREME-SRT8 is online now
