Originally Posted by CSand78
The Ride looks great 300onDueces. I'm looking into getting the Eibach Springs for my AWD 300C. Can anyone tell me if I'd need to make some suspension adjustments in order to put on 22's?? I was looking into putting TIS02's. As of right now I know I can put 20's on it without any problems.
Thanks for the props.
You don't have to make any suspension adjustments in order to make the 22s fit. Just don't go bigger than 265/35/22 on the tires and make sure your wheels have the right offset.
The AWD models have a high positive offset. My wheels are a +40mm offset. If you use the wheels with offsets designed for a RWD model they will stick out and you will have problems with rubbing.
You may also want to buy a Superchips Flashpaq to re-calibrate your speedometer for the larger wheels. Mine was off +7mph@70mph
