Old 07-11-2006, 09:16 PM   #1 (permalink)
Points: 2,149, Level: 1 Points: 2,149, Level: 1 Points: 2,149, Level: 1
Car: 06 chrysler 300
Member Number: 5177
How much lower is srt8?
how much lower is a srt8 then a base model? what is the best way to set the base the same height? one person says the Eibach springs are good another says they are bad. who do i listen to? also is it true that your shocks will wear out very fast with lowering springs and if you have four people in the car it bottoms out? any help with this would be great. i want to lower my car but i dont want a ton of problems nor do i want to spend a ton.
trickdout69 is offline
Old 07-11-2006, 10:15 PM   #2 (permalink)
Points: 7,939, Level: 1 Points: 7,939, Level: 1 Points: 7,939, Level: 1
Tork Monster's Avatar
Car: 2006 Chrysler 300C SRT-8
Member Number: 6292
No doubt there will be subsequent posts to correct any errors I make in this reply, but here is a start:
The SRT-8 suspension sets the car 1/2" lower than the standard model. The springs are stiffer and the shocks are heavier-duty for better control. There are many other differences but I assume you are only looking at the springs and shocks. Or maybe just the springs...
Regarding after-market springs, Eibach is the premier spring supplier, and they build a good product. The two types offered for the 300 is the sportline, which lowers the car 2" and the prokit which lowers the car 1.6"(appx). I believe the sportline also has a higher spring rate.
The bottoming out problem occurs when the car is lowered too far, or if the car is lowered by cutting the stock coils rather than installing proper lowering coils that are stiffer. What happens is the car's suspension compresses to the point that the suspension stops hit the rubber "snubbers". This makes the suspension bounce back and causes the car to "pogo". You see it all the time with the rice-burners who have cut their coils to the max. I first lowered my BMW by cutting a coil and the car pogo'd like crazy. I quickly installed Eibachs and trimmed 5/8" off the ends of the snubbers. This solved the problem, but I also installed Bilstein struts to get better control.
If you lower the car with just springs, then the springs will over-power the shocks and the handling will not be optimal. O.K. for cruzin, but not if you really want to improve the way the car handles.
So, you can cut the stock coils just for looks (you will end up doing it over later), you can install Eibachs and improve the handling and the looks, or change both springs and shocks and greatly improve the suspension.
Another option is to install the springs and shocks off an SRT-8. Since so many owners are installing KW coilovers, the old suspension is often available through here or eBay. I just saw a complete setup go on eBay for under $400.
I have KW coilovers (they replace both springs and shocks/struts) on order, and once I receive them I will sell the original suspension. Let me know if you are interested. The SRT-8 wheels will follow
Reviewing what I just wrote, I realized that I have never seen any posts here regarding replacing the shocks on 300's with Bilsteins or Koni's, etc. I have always upgraded shocks/struts when lowering a car. Not always at first, but sooner or later when I am fed up with the handling. But I am a fairly aggressive driver. Maybe others have not had this problem with the 300... ?
Regarding the longer stock shocks/struts not working properly with a lowered suspension, this has been a point of arguement for years amongst my gearhead buddys. The valving within a shock cannot tell when it it operating lower in the tube; it is only when it reaches the bottom that things would go awry. None the less, the KW struts are shorter to better operate on a lowered car. I would like to hear feedback on this phenomenon.
O.K., I'm getting a glass of wine and wait to be blasted with conflicting opinions...
just kruzin' . . . . . Jay
Tork Monster is offline
Old 07-11-2006, 10:31 PM   #3 (permalink)
Points: 16,908, Level: 1 Points: 16,908, Level: 1 Points: 16,908, Level: 1
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (10)
The bottoming out problem occurs when the car is lowered too far, or if the car is lowered by cutting the stock coils rather than installing proper lowering coils that are stiffer. What happens is the car's suspension compresses to the point that the suspension stops hit the rubber "snubbers". This makes the suspension bounce back and causes the car to "pogo". You see it al the time with the rice-burners who have cut their coils to the max. I first lowered my BMW by cutting a coil and the car pogo'd like crazy. I quickly installed Eibachs and trimmed 5/8" off the ends of the snubbers. This solved the problem, but I also installed Bilstein struts to get better control.
What kind of wine are you refering to?
Moose is offline
Old 07-11-2006, 10:59 PM   #4 (permalink)
Member Number: 6292
Moose- So I was laughing at your response and my wife asked "what's up?"
I said "oh, it's a reply from Moose"
She said "who's Moose?"
I said "Um... a premium member"
She said "You mean like a large penis?"
Fetser Cab (I'm cheap)
Old 07-11-2006, 11:18 PM   #5 (permalink)
Member Number: 232
The SRT8 is 1/2" lower, as Tork Monster already said.
The SRT8 ground clearance is 5.1 inches, and the 300 is 5.6 inches.
I lowered my car 1" in the front, and 1.25" in the rear with KW coilovers.
I was originally worried about lowering my car, but after about 2 months I have only bottomed out entering/existing my driveway. I now think a drop of 1" front and 1.25" rear is a perfect setting. It retains a small rake, no real issues bottoming out, and the car does look much better lowered.
joey is online now
Old 07-11-2006, 11:38 PM   #6 (permalink)
Member Number: 6292
Yeah it does! Your car looks great!
I wouldn't have thought that 1"/1.5" would be enough, but you corrected my view.
Thanks for the pic!
Old 07-12-2006, 08:33 PM   #7 (permalink)
Points: 2,553, Level: 1 Points: 2,553, Level: 1 Points: 2,553, Level: 1
Member Number: 5916
I think that Tork Monster summed it up very well. I have been reading through the various posts over the last couple weeks so I could make the best decision for my car and budget. My findings would match what he said. The only thing he left out is the get rid of crappy stock Continental tires to improve handling (if applicable).
Based on the research the best kit out there by far is the KW kit that can be purchased for $1,400 and if you add the Hotchkis sway bars for another $360, the 300 could handle like a champ.
I coudn't spend that kind of money on one mod for the car so I ordered the Hotchkis stage 1 kit which includes lowering springs and sway bar kit. It seemed to be the second best option at $620. I will get it installed next week when it arrives. I will let you know what I think.
I was going to upgrade to the SRT-8 suspension but some criticism of it being floaty steered me away from it.
2005 Chrysler 300C, Silver. Hotchkis lowering springs and subframe connectors.
Fleck 5 is offline
Old 07-18-2006, 10:55 PM   #8 (permalink)
Points: 1,777, Level: 1 Points: 1,777, Level: 1 Points: 1,777, Level: 1
Fire Ace's Avatar
Car: 2002 Chevrolet Camaro SS
Member Number: 6800
One thing I would recommend is to stay away from Eibach Sportline springs. They lower the car way too much and after a while they will settle even lower, around 2.5 inches. They are purely for looks and not handling. There is no shock/strut that can correctly dampen the spring. The best bet is a coil over kit like already mentioned.
Fire Ace is offline
