Old 07-20-2006, 10:20 PM   #1 (permalink)
Points: 3,334, Level: 1 Points: 3,334, Level: 1 Points: 3,334, Level: 1
1SRT8-2NV's Avatar
Car: 2006 SRT8 300
Member Number: 4389
CLunking NoIse!!
Well after installing the KW V2 coilovers and the Magnaflow catback a few weeks ago I was consistently having to go back and tighten a bolt here and a bolt there. But I thought all was well and I had fixed all of the suspension noises, BUT now I have this terrible clunking sound when I hit a bump. It sounds like it is coming from under the car on the passenger side somewhere from the middle of the car to the rear. I can never nail down the exact spot and it is very frustrating. I have already gone back and totally taken the suspension apart and then reinstalled it and it is all good. Also the Magnaflow catback seems to be installed correctly and it seems to be good and tight.
The noise almost sounds like the exhaust is hitting the rear axle when I hit a bump but I keep thinking to my self that this is not possible. If anyone has any idea what problem I could be dealing with I would much appreciate it.
Click Here to view my 2006 300C SRT8 Cardomain Site ---> http://www.cardomain.com/ride/2394755
Click Here to view my last car 2000 Maxima ---> http://www.cardomain.com/ride/132737
1SRT8-2NV is offline
Old 07-20-2006, 11:14 PM   #2 (permalink)
Points: 12,931, Level: 1 Points: 12,931, Level: 1 Points: 12,931, Level: 1
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
Trader Rating: (4)
Cross brace.
Slow down over bumps.
crhemi is offline
Old 07-21-2006, 06:52 PM   #3 (permalink)
Member Number: 5047
Check the rear shocks also, you have to tighten the **** out of them.
-Zack Ratcliff
800-864-2470
Old 07-23-2006, 10:54 AM   #4 (permalink)
1SRT8-2NV's Avatar
Car: 2006 SRT8 300
Member Number: 4389
Will do, thanks for the response.
You to crhemi, but in south mississippi the bumps are everywhere!!!!
Old 07-23-2006, 03:57 PM   #5 (permalink)
crhemi's Avatar
Member Number: 3307
Trader Rating: (4)
Sorry, I thought you ment speed bumps
crhemi is offline
Old 07-27-2006, 11:13 AM   #6 (permalink)
Points: 3,410, Level: 1 Points: 3,410, Level: 1 Points: 3,410, Level: 1
jjhuckleberry's Avatar
Car: 2006 BRT SLV, 300C AWD
Member Number: 2537
Its not the suspension. Its the Magnaflow. The exhaust has shifted on the bracket and is traveling up when you hit bumps. You need to put the car up on a hoist and move it back over and secure it. permanently!
I had the same experience.
Joe
2006 300C AWD
Brt Slv, colr mud flaps
20" Mc2 FZ16 w/ Nittos
K&N CAI,Tbyrne TBS
30% Tint, SuperChip Flashpaq
Just installed:
KW V2
Corsa Exhaust
GSM Torque/Fan Mod
jjhuckleberry is offline
Old 08-02-2006, 08:05 PM   #7 (permalink)
1SRT8-2NV's Avatar
Car: 2006 SRT8 300
Member Number: 4389
Thanks for the information because I have still not been able to fix this problem.
Old 08-08-2006, 12:42 PM   #8 (permalink)
Points: 9,803, Level: 1 Points: 9,803, Level: 1 Points: 9,803, Level: 1
turbohips's Avatar
Car: 2005 Chrysler 300c AWD
Member Number: 952
I had the same problem. I at first thought the same thing with regards to my exhaust. I later came to find that my transmission was loose and there is a TSB out for that problem. The knocking sounded like it was coming from under my arm rest. There is apparently a bolt that tends to come loose that holds our transmission down. It took my dealer two days to fix it. Now there is no knocking sound anywhere. I hope this info helps.
Volant CAI, JBA headers, JBA cat-less mids, Borla exhaust, Inertia Street heads, Spartan cam 114 LSA, underdrive pulley, 180 thermo, programmer
hotel website design
hotel seo
hotel marketing
hotel printing
turbohips is offline
Old 08-09-2006, 05:19 PM   #9 (permalink)
Member Number: 2537
What is the TSB code? I have not seen the bulletin listed yet.
