Old 07-25-2006, 09:00 PM   #11 (permalink)
Points: 29,511, Level: 1 Points: 29,511, Level: 1 Points: 29,511, Level: 1
HEMMISSEY's Avatar
Car: 2005 300c VIP Modular Forged Wheels
Member Number: 983
get the a pillar pod, and mounted in there..
<--12" WIDE--> Club
Slammed and cambered out...
HEMMISSEY is offline
Old 07-26-2006, 06:16 PM   #12 (permalink)
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
I think that would be a better!!
DUBSTER is offline
Old 07-26-2006, 06:56 PM   #13 (permalink)
Points: 9,742, Level: 1 Points: 9,742, Level: 1 Points: 9,742, Level: 1
kalo's 300C's Avatar
Member Number: 5488
Thumbs up good idea
I was thinking bout the Pillar pod but I dont knwo if wifey will like it I'll ask and see what she says. Thanks again guys, oh the clock I knwo she aint going with that ... Aloha Seth & Carol....
kalo's 300C is offline
Old 07-26-2006, 07:02 PM   #14 (permalink)
DUBSTER's Avatar
Member Number: 4939
GOOD LUCK!!!!!
DUBSTER is offline
Old 07-30-2006, 04:19 PM   #15 (permalink)
Blowndakrt's Avatar
Member Number: 1851
I put mine in the ashtray. That way I can close it and it be out of the way.
I can't seem to attach pics very well right now. Keeps saying the file is too big, but if I shrink it down to get close to the file size it recommends, the picture is too small.
Shawn
Blowndakrt is offline
Old 07-30-2006, 05:44 PM   #16 (permalink)
Member Number: 5488
Thumbs up ashtray
Shawn
kool how did you atatch it to the ashtray and how did you run the wire to it, like you I would like to be able to hide it away... thanks for your help Seth & Carol.....
Old 07-30-2006, 06:10 PM   #17 (permalink)
Blowndakrt's Avatar
Member Number: 1851
I removed the ashtray and then cut out some plastic where it has the dividing part from the ashtray and lighter spots. Then I took a piece of abs plastic and cut it to fit on the top of the ashtray. Then I used plastic expoxy to glue the abs plastic to the ashtray, then sanded, smoothed, and painted it.
Just be carefull to mask off the front and the sides of the ashtray. I got some paint on the sides and it doesn't slide back and forth very well. So I need to pull it apart and sand the sides down so it won't bind up. Either that or get a stronger spring mechanism for it.
I have the Dakota Digital ride controller. I mounted the brain to the metal knee bolster underneath the steering wheel. Then I ran the wires across the underside of the dash to behind the factory radio. Drilled a hole in the backside of the ashtray to run the wires up to the controller.
If you want, email me at Blowndakrt@mchsi.com and I can reply with a picture of the unit mounted.
Shawn
Old 08-03-2006, 02:17 PM   #18 (permalink)
Points: 9,242, Level: 1 Points: 9,242, Level: 1 Points: 9,242, Level: 1
LAIDBACKC's Avatar
Member Number: 1368
HERE THEY ARE!!
DUB... that is wut im talkin about... NICE... FREAKIN... INSTALL
LAIDBACKC is offline
