Old 08-16-2006, 10:50 AM   #1 (permalink)
Points: 1,969, Level: 1 Points: 1,969, Level: 1 Points: 1,969, Level: 1
norcal's Avatar
Car: 06 Chrysler 300c
Member Number: 6537
Fender liner rub
Fender liner question...
22" tis with 265/35/22 w/ Eibach 1.6"
If the fender liner rubs the tires on top when in reverse or over bumps, should i cut that part out? I had the fenders rolled and the liner was not stretched correctly so it hangs a bit. If I cut some out, it would allow water up in that area... What would be the best thing to do?
Also, when the fender was rolled the paint did crack, going to put touch up in that area.
next will be too check if the tires are rubbing the arm!!
thanks
norcal is offline
Old 08-17-2006, 01:04 AM   #2 (permalink)
Points: 28,698, Level: 1 Points: 28,698, Level: 1 Points: 28,698, Level: 1
HEMMISSEY's Avatar
Car: 2005 300c VIP Modular Forged Wheels
Member Number: 983
Norcal, can you post some pic's of the liner hanging? IMO,if they hang, i would trim a lil bit off. Btw, The reason why the paint cracked, was because the paint wasn't heated correctly, before it was rolled.
<--12" WIDE--> Club
Slammed and cambered out...
HEMMISSEY is offline
Old 08-17-2006, 07:48 PM   #3 (permalink)
Member Number: 5047
Another thing to check is that its not rubbing against your spindle. On my wheels when i would go in reverse and turn it would rub against the spindle. if so add a 3 mm spacer or grind the spindle a little to clear.
-Zack Ratcliff
800-864-2470
Old 08-18-2006, 01:11 AM   #4 (permalink)
Points: 4,086, Level: 1 Points: 4,086, Level: 1 Points: 4,086, Level: 1
snoopdolks's Avatar
Car: 2006 Chrysler 300C (Aussie Spec)
Member Number: 4057
thanks
One of the other Aussies, MY300 had a similar issue and used a heat gun to fix the problem - presumably without cutting anything. You might want to PM him for some advice.
Hope that helps, Sean.
snoopdolks is offline
Old 08-20-2006, 12:15 AM   #5 (permalink)
norcal's Avatar
Member Number: 6537
Thanks for the replys guys.
I will take pics tomorrow.
I feel the liner already got a cut in it from the rubbing, mostly likely will be cutting it and putting some sort of kydex or other plastic material to cover up the area
norcal is offline
Old 08-20-2006, 12:48 AM   #6 (permalink)
norcal's Avatar
Member Number: 6537
norcal is offline
Old 08-28-2006, 12:14 AM   #7 (permalink)
norcal's Avatar
Member Number: 6537
well, had to borrow a camera, mine is worthless
here are 2 pics of the liner, sounds like it only rubs in reverse but some cutting and modding the area with some other material will most likely be needed.
ID:	16602   fender-liner-rub-22-2-.jpg.jpg
norcal is offline
Old 08-29-2006, 03:02 PM   #8 (permalink)
Member Number: 5047
Check the distance from spindle to back side of wheel.
Old 08-29-2006, 11:48 PM   #9 (permalink)
norcal's Avatar
Member Number: 6537
what is the easiest way to do this with the wheel on the car and the car not lifted off of the ground?
norcal is offline
