Spittin...
http://www.300cforums.com/forums/vbp...?do=view&g=317 in case you missed it the first time. I posted this on your last thread on this same subject
AWD Lowering?. The tires in the pictures have a diameter of 29.9. Even though you are going with 22's I doubt your tire diameter could be much bigger. Hope this helps with your decision.
Also, don't be fooled by the fact that Eibach makes a Pro Dampener Kit...even though the Pro Spring Kit works for the AWD the Pro Dampener Kit does not. Once you've installed the Pro Spring Kit, and they shread your stock shocks, I know of no replacement shock that is fit for those springs! If I would have known that the Pro Dampeners did not work on my AWD, even though they are made for the Pro Springs, I would not have bought the Eibach's.
