Old 09-16-2006, 09:42 PM   #1 (permalink)
Points: 1,871, Level: 1 Points: 1,871, Level: 1 Points: 1,871, Level: 1
Car: 2006 chrysler 300srt
Member Number: 6368
Need suspension help!
I have an 06 300srt and installed kw coilovers and GS 22” wheels. I sent the car in for a wheel alignment but the car still tracks all over the place. I have the height adjustment set pretty low but we made sure to have the exact same height at each corner. Where did I go wrong? Is there a minimum height that I went beyond? Or is this normal when you install 22” wheels?
biiig-hp is offline
Old 09-17-2006, 06:18 AM   #2 (permalink)
Points: 4,952, Level: 1 Points: 4,952, Level: 1 Points: 4,952, Level: 1
turk182's Avatar
Car: 06 Black 300c 5.7
Member Number: 4352
i got 22s soon to be 24s and i dont have this problem, im not using coilovers but custom suspension and went even lower than you, mabye someone will chime in who has had a similar problem
turk182 is offline
Old 09-17-2006, 06:24 AM   #3 (permalink)
Points: 2,349, Level: 1 Points: 2,349, Level: 1 Points: 2,349, Level: 1
Car: 2006 Chryler 300C SRT8
Member Number: 5724
Did you have your car aligned at your travel height? Post your toe, caster, and chamber information for the front and rear. This would help us to steer you straight. List your fender lip to wheel center measure for added info.
Dave
FIXER is offline
