Originally Posted by inkwell
For those with the total setup of Swaybars and the coilovers, how little drop can you set them for? I bump my chin often enough with the stock suspension. If anyone has had them on for any length of time, will the car settle further over time beyond the drop when they are installed?
Sways don't effect height. Maybe I am wrong, but it is my understanding from KW Automotive that the only thing that effects height is the springs. The struts have nothing to do with height. The weight of the car is resting on the springs.
My KW's springs took about 2 months to fully settle about 1/4" to 3/8".
On a side note, I have had a problem with my front springs/installation since day 1, or about 6 months. I explained the problem in this thread
KW problem or not?
It appears my left spring is compressing more than the right which is forcing me to raise the left spring height adjuster about 3/4" more than the right side.
KW is sending me two new front springs as a possible solution. I should have them this week. During my discussions with KW, they said the only thing that could cause my sagging front end is a faulty installation, or a failing spring.
