Old 11-28-2006, 10:01 PM   #1 (permalink)
Tork Monster
Tork Monster's Avatar
Car: 2006 Chrysler 300C SRT-8
Member Number: 6292
>> How To: KW Coil-overs Installation
INSTALLATION OF KW VARIANT II COIL-OVER SUSPENSION ON A 300C SRT8
WARNING!
THE FOLLOWING DESCRIPTION IS NOT AN APPROVED GUIDELINE NOR INSTRUCTIONS ON HOW TO INSTALL SUSPENSION COMPONENTS. SERVICING SUSPENSION AND THE USE OF SPRING COMPRESSORS IS DANGEROUS AND COULD RESULT IN SERIOUS INJURY. INCORRECT INSTALLATION OF SUSPENSION COMPONENTS COULD RESULT IN SUSPENSION FAILURE AND LOSS OF VEHICLE CONTROL. IT IS RECOMMENDED THAT SUSPENSION WORK BE DONE BY EXPERIENCED PROFESSIONALS. THE FOLLOWING IS SIMPLY A DESCRIPTION OF HOW ONE PERSON INSTALLED THE KW VAR II COIL-OVER SUSPENSION ON HIS PERSONAL CAR AS A WAY OF RECORDING THE METHOD FOR FUTURE PERSONAL REFERENCE. THIS MAY ALSO BE VIEWED AS AN ILLUSTRATED METHOD OF DISCOURAGING THOSE FROM ATTEMPTING THIS WORK THEMSELVES. THE TEXT IS WRITTEN IN “INSTRUCTIVE” FORMAT FOR BETTER VISUALIZATION.
Whenever jacking a car for any reason, the car should be parked on a level concrete pad. Working on a slope or on unstable surface can result in damage to the vehicle and/or injury.
Measure the distance to the fender for all four corners. Record this to use as a reference later.
Install wheel chocks on the wheels opposite from the wheel you are working.
The owners manual says nothing about how to jack the car, although placing the jack in the wrong place can damage the vehicle.
There is a rubber mount under the sills by rear door on each side for the rear jacking points. The fronts are located further towards the center of the car. See illustration:
FRONT SUSPENSION:
Raise the front on one side of the vehicle. Install a jack stand adjacent to the floor jack to distribute the load and improve stability. Remove the front wheel. Place the removed wheel under the car just behind the jack stand, as an extra safety measure in case the vehicle shifts while raised.
Install a set of dual spring compressor tools on either side of the spring (NOTE: There are many different types of spring compression tools, most of which will not fit in the tight confines of the LX platform front suspension).
Make sure the number of coils between the clamps is the same on each side. Tighten the clamps equally until the spring is loose.
(NOTE: The compression tools must be installed with the drive nuts on top, but fitting a wrench in this position can be difficult. One trick is to install double-nuts on the bottom of the thread so the screw can be tightened from the bottom of the tool)
The shock and spring assembly is held in place by
(3) bolts on the top shock tower,
(1) bolt through the lower control arm,
(1) bolt attaching the sway bar.
Once the coil is loose, the bottom bolt in the control arm can be removed.
It is best to remove the shock from the top mount before removing the three bolts holding the shock mount to the tower. This requires an offset 18mm wrench and an 8mm socket. Hold the shock shaft from rotating with the 8mm wrench, and loosen the 18mm nut.
Note: The 18mm wrench shown here is not properly offset to allow for complete engagement with the nut.
Remove the three shock mount bolts.
Remove the nut holding the upper control arm
Use a Ball Joint Separation Tool (pickle fork) to break the spindle from the upper control arm. This may require several heavy blows; don’t hit your fender!
Once the spindle is separated from the control arm, the bolt holding the sway bar can be removed .
(CAUTION: the sway bar will be loaded from the other side, so will be trying to push this bolt upward. Use care when removing!)
The shock/spring assembly can now be removed.
Remove the upper shock mount and rubber pad from the original shock and install it on the new spring. Slide the spring and mount onto the new KW shock and install the top nut to hold things together. Adjust the threaded spring perch following the KW instructions.
NOTE: the front assembly can be installed without compressing the spring if the perch is positioned as low as possible. The perch can be repositioned after the assembly is installed
Install the new assembly into position in the car.
Raise the spindle and reassemble it to the upper control arm. The ball joint will spin when you try to tighten the nut, so you may have to hold the control arm down to lock the tapered shaft of the ball joint in place to stop it from spinning.
USE CAUTION NOT TO DAMAGE THE UPPER CONTROL ARM !!
Install the lower control arm bolt, the sway bar bolt and the three upper shock mounting bolts and tighten securely (refer to manufacturers recommendations for torque values). Tighten the top nut holding the shock to the top mount.
Be very careful not to strip or damage the nut or especially the shock rod.
Follow the KW instructions to adjust the rebound rate (V2 and V3 only).
Mount wheel and lower the car (NOTE: the car will sit lower now, and there may be interference with the floor jack. Placing a 2”x10” under the tire before lowering the jack will allow for extra clearance).
Repeat for other side.
NEXT: Rear Suspension...
just kruzin' . . . . . Jay
Tork Monster is offline
Old 11-28-2006, 10:04 PM   #2 (permalink)
300customs
300customs's Avatar
Car: 2005 Chrysler 300c
Member Number: 15225
great write-up!
300customs is offline
Old 11-28-2006, 10:15 PM   #3 (permalink)
Tork Monster
Member Number: 6292
Rear Suspension...
REAR SUSPENSION:
Block the front tires and raise the rear on the side you are working. Install a jack stand adjacent to the floor jack to distribute the load and improve stability. Remove the wheel and place it under the “frame” of the car.
The shock must first be removed to access the spring.
CAUTION
THE REAR SHOCKS ON THE SRT8 ARE GAS CHARGED. THIS COMPRESSED GAS WILL CAUSE THE SHOCK TO EXPAND RAPIDLY AND CAN CAUSE SERIOUS INJURY. THE METHOD THE OWNER USED TO RETAIN THE GAS-CHARGED SHOCK IS NOT AN APPROVED METHOD AND COULD RESULT IN INJURY IF DUPLICATED. THIS IS SHOWN FOR ILLUSTRATIVE PURPOSES ONLY
The shock cannot be removed unless held in a collapsed state, or without disconnecting the lower control arm. Since the inner bolt holding the control arm is installed so that it cannot be removed without first removing the exhaust, I chose to use a retaining wire to hold the shocks in a collapsed position.
The way I did it:
Remove the lower bolt mounting the shock to the lower control arm.
Remove the two upper shock mounting bolts. Use a 6’ pry bar between the control arm and the frame to assist in lowering the lower control arm below the “natural state” (BE CAREFUL NOT TO DAMAGE EITHER THE FRAME OR THE CONTROL ARM!). Insert a pry bar between the top shock flange mount and the body to create enough space to thread a 10-gauge wire through each of the bolt holes. Wrap two more wires around the lower shock rod, below the shock body.
Use a second floor jack to raise the lower control arm and compress the shock (place the jack “cup” under the shock; do not jack linkage, ball joints or other suspension joints).
Raise the control arm until the cars weight begins to rise off the frame jack. Tie the wires together. Do not fatigue or over-tighten the wires.
Lower the jack under the control arm. Inspect the wires (USE SAFETY GLASSES!).
Hold the suspension down with the large pry bar and remove the shock (BE CAREFUL!!)
The individual spring compression tools used on the front coils will not work on the rears. A hinged external spring compressor must be used to fit within the tight confines of the suspension (NOTE: the compression tool shown here is not typically available from rental shops, and the larger model more easily found will not fit… arghh!)
Install the hinged compression tool and compress the spring.
Remove the spring from the car. Remove the upper rubber pad along with the spring.
Install the compressor on the new spring. The spring must be positioned in the tool so the lower end of the coil is in the same position as the “pocket” in the rubber pad resting in the lower control arm.
Install the KW threaded coil perch on the top of the spring. Adjust the perch to the preferred setting (NOTE: I threaded the nut to within 3/16” of bottoming out and the rear was lowered only 1.2”, but some settling is expected)
The threaded perch sits into a recessed pocket in the car and cannot be adjusted without compressing the spring again, so set the position as accurate as possible!
Install the compressed spring into the car. Make sure the coil position matches the sculpted rubber base pad; remove and adjust if necessary.
NOTE: the threaded rod on the compression tool may hit a secondary suspension rod attached to the lower control arm. Removing the mounting bolt may be necessary.
There is a brake sensor line connected to this rod and can easily be damaged by the compressor tool. Remove this line from the clips and check it often to make sure it is not being damaged by the work.
Loosen the compression tool and make sure the spring is sitting properly in position.
Using the KW adjustment knob, adjust the rebound rate on the KW shock to the preferred setting.
Raise the shock into position and install the (2) upper mounting bolts.
Place a second floor jack under the lower control arm and raise the arm until the lower shock assembly bolt can be installed. Tighten securely.
Install the bolt holding the secondary suspension rod.
Tighten all assembly bolts to the torque rating recommended by the manufacturer.
Install the wheel. Lower the jack and re-torque the lug nuts.
Repeat for the other side.
The car will not sit properly until you drive it, as the raising and lowering of the jacks will preload the tires and not allow the car to sit “square” to the pavement. The coils will also settle between 1/4”-1/2” in the first few weeks of driving, so a second adjustment of the spring perches may be necessary.
The suspension will need to be professionally aligned after the heights are all final or uneven tire wear and handling irregularities may result.
Listen carefully for any knocking or clunks when driving, which could indicate a loose part or assembly bolts not properly tightened.
happy, happy, joy, joy.
NEXT: How to repair a broken front spoiler because your new lowered ride sits too damn low…
Old 11-28-2006, 11:24 PM   #4 (permalink)
joey
Member Number: 232
Thanks Tork! It looks so simple, but then so difficult. I am mechanically challenged, and don't have the tools, so I paid dearly to have mine installed.
The only additional info that would really help are the torque settings for all the different bolts. Did you need more than one torque wrench?
One warning about the boot seal on the upper control arm, and using the picket fork. My boot seal was damaged during the install, creating a big hole. Chrysler doesn't sell boot seals separate, and the entire upper control arm had to be replaced for about $175.
joey is online now
Old 11-29-2006, 09:39 AM   #5 (permalink)
Tork Monster
Member Number: 6292
Good point, Joey-
I was concerned with damaging the boot using that pickle fork. I thought later that I should have at least covered the boot with a lubricant to allow the fork to slide on the rubber rather than rip it; but I lucked out anyway.
Jay
Old 11-29-2006, 09:50 AM   #6 (permalink)
HEMMISSEY
HEMMISSEY's Avatar
Car: 2005 300c Team Kartier Forged
Member Number: 983
NICE WRITE UP T.M!!!!!!!!!!! I vote for Sticky!
HEMMISSEY is offline
Old 11-29-2006, 10:10 AM   #7 (permalink)
pmpn8ez
pmpn8ez's Avatar
Car: 2006 Dodge Charger SRT8
Member Number: 2022
Trader Rating: (4)
Great write up Tork!!!!!
One thing of great importance to add is:
For those that are concerned about damaging the rubber boot that Joey and Tork are talking about (175 bux to replace!!!!), ther is ANOTHER way to get the front spring out without touching this!!!!!
All you have to do is follow Tork's directions to a "T" until you get to the part where you use the "pickle fork" to seperate......
At this point, make sure everything is unbolted from the shock and spring assembly (all bolts and get the speed sensor cables and such out of the way too)......THEN instead of using the "fork"........
1) unbolt the caliper and pads from the rotor and remove out of the way in order to make clearance room.
2) use a large pry bar and wedge between the frame and lower control arm.
3) push down on the bar (dont worry, it wont break!!!), this will bring the whole unit downward giving you enough room to wiggle the whole shock assembly out from the upper and lower control arm unit.
This worked for me a few weeks ago when I installed the mopar lowering springs!!
A few things to consider and others might want to weigh in on is:
I re-used the stock shocks, so re-applying the shock was no problem with this alternative step.....I dont know if the KW's are longer and if there is an issue with having enough room to re-apply........
Also, I had my car on a lift, not on jacks......so be CAREFUL when you are prying downward on the bar to lower the component to achieve room to get the shock assembly out!!!!!! It takes ALOT of force to achieve enough room to force the shock out!!!!!
BUT....this is an alternative for those that are worried about damaging the rubber boot!!!!!!
Halos, 22's, BT emblem, LED interior, Jl 12's, 2 sets of JL 6.5 components, JL 500/1 and 300/4, Tinted tails & sides, 35% Tint, factorone HID's, K&N Aircharger CAI, visor covers, MRK Silver knobs, 22elite padded center console & door rests, red stitched shift knob
now on to more performance goodies!
pmpn8ez is online now
Old 11-29-2006, 10:16 AM   #8 (permalink)
crhemi
crhemi's Avatar
Member Number: 3307
Very helpful, thank you!
Now to get the time and courage to attempt my installation.
crhemi is offline
Old 11-29-2006, 11:43 AM   #9 (permalink)
pmpn8ez
pmpn8ez's Avatar
Member Number: 2022
Trader Rating: (4)
Hemmissey..........I thought you changed it?????
I was highly disappointed when I saw that it was gone!!
Old 11-29-2006, 02:31 PM   #10 (permalink)
Tork Monster
Member Number: 6292
Pmpn,
Great advice!
I used a 6-foot prybar on the rear lower control arms, but I split the ball joints before trying that on the front. I own a pickle fork from so many lowering jobs in the past... it just seemed natural to do it that way.
I don't like using a prybar on forged control arms, but I don't like rippin the ball joint boots either!
Thanks-
Jay
