Old 03-10-2007, 01:22 AM   #101 (permalink)
Points: 10,804, Level: 1 Points: 10,804, Level: 1 Points: 10,804, Level: 1
Simans82's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 3988
Thumbs up
Originally Posted by Daddydough View Post
This is a very nice write up! The colormatched Wheels in Midnight Blue looks sweet! Congrats on a Sweet intall!
I appreciate it. I'm very glad with the way it turned out.
Simans82 is offline
Old 03-10-2007, 01:22 AM   #102 (permalink)
Simans82's Avatar
Member Number: 3988
Originally Posted by Hustler View Post
You have done a damn good job there bro...... That thing looks awsome! congrats on the install
Thanks! How is your install going? Can't wait to see some pics.
Simans82 is offline
Old 03-11-2007, 11:46 AM   #103 (permalink)
Blowndakrt's Avatar
Member Number: 1851
"Q:
hey, when you mounted your rear cups, how did you secure the top cup in place? I got the bottom one secured with the bolt that goes through the lower control arm and attaches with a big washer and a nut. I just couldnt figure out how to mount the top cups in place. It came with 2 long bolts. Any ideas??
Thanks
A:
If you're talking about actually "seating" the rear cups when you have them on the car, you're going to have to have a pry bar on the top pushing them towards the upper mount and have someone air them up ever so slightly so they set themselves in.
You'll have to make sure to FULLY air up the rear after they are seated so they STAY seated. Then when you let the car down, you won't have any problems."
You can also take the 2 long bolts with nuts and use those to attach your the upper cups. You simply drill a hole through the upper spring perch and the upper cups. Then slide the bolt through the holes and attach the nut. This will help secure the upper cups into the spring perch and you won't have to worry about them coming out. Granted you won't have many instances that these will come out but they are good to have bolted in place. The most common place I can think of is when I got my oil changed at the dealership. This perticular dealership used a lift to raise my car since they did not have a pit. This will cause the cups to drop down even if you have them fully inflated.
It also helps if you are making a sharp turn up an incline, such as a driveway. Sometimes you will get a small clank in the back from the cups shifting a little bit. Bolting them in stops that.
Shawn
Blowndakrt is offline
Old 03-11-2007, 01:24 PM   #104 (permalink)
Simans82's Avatar
Member Number: 3988
Shawn
Great info Shawn! Thanks so much for the post!
Simans82 is offline
Old 03-11-2007, 06:32 PM   #105 (permalink)
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
"Q:
Thanks
A:
Shawn
I have my rear cups installed without the bolts. I do get that clank when I go up a curb.
DUBSTER is offline
Old 03-11-2007, 08:52 PM   #106 (permalink)
Points: 3,557, Level: 1 Points: 3,557, Level: 1 Points: 3,557, Level: 1
Hustler's Avatar
Car: 2005 chrysler 300c
Member Number: 5356
Blowndakrt
What is the exact length/width of bolt to use? And do you have any recomendations where to drill the holes?
There is a killer curb i hit everyday to get to a strip mall near by and i had my chev lowrider do the same thing... I gotta get em bolted as i hit this hump on an angle usualy doing 50k
"Its not my tires screaming, Its the asphalt"
Hustler is offline
Old 03-11-2007, 08:57 PM   #107 (permalink)
Hustler's Avatar
Member Number: 5356
Simans82
Still waiting on the air guage mount i ordered.... and im recovering from my 26th Bday....ehhh redbull and jagermister....... ehhh no way i would do this install half cocked (well that day but not the next morn)
Im going to bite the bullet friday/saturday.... ill post pics when i get back
Hustler is offline
Old 03-11-2007, 09:05 PM   #108 (permalink)
Blowndakrt's Avatar
Member Number: 1851
Blowndakrt
I will get the bolt size tomorrow. They are all at the shop. I didn't get them when I orignally ordered my kit last summer. So I asked Zack to send me the bolt kit when I ordered my other tank and compressors. I believe they are sending them with the kits now, so make sure yours are not there.
I wasn't gonna bother asking Zack for them since they are easy to get at any hardware store. When I called to order my stuff, I asked Zack about what bolt size I would need and he said he would just throw them in with my order. That's UAS for ya. Number one company do business with.
Shawn
Old 03-11-2007, 09:08 PM   #109 (permalink)
Blowndakrt's Avatar
Member Number: 1851
When I ordered my kit last summer, I didn't get them. I wasn't really worried about it since they can be gotten at any hardware store. I noticed the clank everytime I pulled into my driveway, so it got a bit annoying. My biggest concern was when the dealership changed my oil. I had to go out and line up the upper cups as they set the car down off the lift. They did not fall out or come out of the upper mount enough to worry about. They would have seated again once the car was set down, but mine were aired all the way up. So in case I forgot to air them all the way up next time, I figured I better do something while I had it apart this time.
Shawn
Old 03-11-2007, 09:13 PM   #110 (permalink)
Hustler's Avatar
Member Number: 5356
Thanks bro, Please let me know..... Im gonna have to do this for sure... Im rough on this little lady
Hustler is offline
