Originally Posted by UniversalAirSuspension
We usually run the lines out to the front though the drain holes under the rear seats and for the back drill a hole for the rear valves.
Zack, Which drain holes are you referring to? I am gonna be redoing my entire setup as you already know and might go that route for mine. Do you tee it before or after the drain holes? This might actually work out well on mine since I am changing the location so I can add the second tank and the other compressors.
I actually have alot more room than I thought I was gonna have. Kinda going a different route than what you suggested over the phone, but it should look clean when its all done.
You said you wanted to see pics as I went along, so here are some pics from thread I started. I will send ya finished pics when its all said and done, like you asked or just check back in that thread. I am posting pics as progress moves along.
It has begun
Shawn
