Old 03-17-2007, 09:41 AM   #141 (permalink)
Simans82's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 3988
Originally Posted by LAIDBACKC View Post
can you still pancake with 265/35??
After speaking with 4u2nv, he went from 265/35/22 to 265/30/22 and got almost another full inch out of his drop when pancaked. That made up my mind on the tire size.
I used to own TIS 07's with 265/35/22, and after going to the 30 series on my second set of wheels I can definitely see why you would get the extra inch. The 30 series is already nearly resting on the plastic liner, and the 35's would have definitely restricted me on the full pancake. The difference in the tire size is easy to tell when you look at how close the tire is to the upper control arm bolt. You have a lot more room with the 30 series than the 35's.
(For reference: the wheel size in both situations was 22" x 9.5" offset 18)
Simans82 is offline
Old 03-17-2007, 10:19 AM   #142 (permalink)
NotYet's Avatar
Member Number: 9392
Simans, how would you say the ride is w/ your 265/30/UAS compared to 265/35/non-UAS setup? The idea of 265/35/22 already scares the ****ens out of me hehe
15% tint all around
KWv2
Startech grill
Clear side markers
Stealth bulbs
Interior LED bulbs
Demolded / Debadged trunk
Visor Disguisers
Hotchkis sway bars
SRT spoiler
RainX Latitude wipers
Tinted tail lights
NotYet is offline
Old 03-17-2007, 11:43 AM   #143 (permalink)
Simans82's Avatar
Member Number: 3988
Thumbs up
There is little to no difference between the two setups. The UAS is a bit more stiff when lowered, but that's to be expected. In my opinion, there is no ride quality difference between the 35 and 30 series tires
I've been riding on aftermarket wheels and suspension on different vehicles for over 9 years though, so taking past experience into account, my opinion may be much different than speaking with someone who's riding on smaller tires for the first time.
Simans82 is offline
Old 03-17-2007, 11:54 AM   #144 (permalink)
NotYet's Avatar
Member Number: 9392
Yea, that'll be me. I'm coming from a truck world to 35 (possibly 30) series tires. It's going to be interesting. hehe
15% tint all around
KWv2
Startech grill
Clear side markers
Stealth bulbs
Interior LED bulbs
Visor Disguisers
Hotchkis sway bars
SRT spoiler
Tinted tail lights
NotYet is offline
Old 03-17-2007, 01:29 PM   #145 (permalink)
300customs's Avatar
Car: 2005 Chrysler 300c
Member Number: 15225
you will get to used to it after a while...be prepared to feel each piece of gravel in the road though...lol
300customs is offline
Old 03-18-2007, 09:08 AM   #146 (permalink)
DUBSTER's Avatar
Car: 2005 CHRYSLER 300
Member Number: 4939
You can but the tires will rest on the inner fender lining. I have 35 series tires.
DUBSTER is offline
Old 03-18-2007, 05:21 PM   #147 (permalink)
LAIDBACKC's Avatar
Member Number: 1368
ok what about
1. Driving in the winter... is this doable?
2. What is the warranty with UAS? lets say I do blow a bag, how fast can I get another one, and is it warrantied?
3. Are the bolts now included in all kits to secure the bags in place (not sure what you guys were talking about, but something can come out? when placed on a lift?)
LAIDBACKC is offline
Old 03-18-2007, 10:07 PM   #148 (permalink)
GROUNDED's Avatar
Member Number: 10038
ok what about
Yes it can be done but the only problem you can run into is cracked water traps as well as frozen valves if you dont empty the water trap or tank and you get water in the valves.
Most shops will replace bags if the bags blow due to factory defect, but most of the time blows bags are due to user error if it be too much psi or, installer error.
From my experience with floating bags they are usually retained by the shock travel or in our case struts and shocks
2005 Chrysler 300
Touring Signature Series
Midnight Blue
35% tint
22" Devino Verve
GROUNDED is offline
Old 03-18-2007, 11:13 PM   #149 (permalink)
LAIDBACKC's Avatar
Member Number: 1368
ok what about
Zack can you answer these please? thanks!
Old 03-19-2007, 08:39 AM   #150 (permalink)
Simans82's Avatar
Member Number: 3988
I drove mine the last month of cold winter weather, and have had zero problems. As GROUNDED has already touched on, I'm sure the catch cans would be a worthwhile investment if you're concerned about freezing water in your system.
I also opted to mount all of the valves inside the trunk. The heat from the compressors running is enough to get them warmed up during the cold months. It was in the single digits for nearly an entire week when I first installed the system, and there were no negative effects.
Originally Posted by UniversalAirSuspension View Post
Thats usually because of the product. The entire air system is only as strong as its weakest link. To prevent those problems we run 2 compressors (failsafe reliability and fast fill). We run all D.O.T. Approved lines and solid brass D.O.T. approv. fittings to prevent leaks. On average if you beat your system hard you will have to replace the compressors after about a yr and half. Otherwise they will last you a long time. On a VW (same bags as the LX) we used for road testing on our bags we are at over 75k miles and the same air system (6 years and running).
We give a 3 yr, 36k mile warranty on the entire system except the compressors, they are 1 yr.
The bolts are now included when you order the UAS kit.
Simans82 is offline
