Originally Posted by Blowndakrt
If you find that the other one seems to be fine, try swapping the leader hose of the good one to the one you think is bad. See if that makes a difference. If it makes the difference, you just need to order a new leader hose.
Shawn
I called Zack @ UAS to order some fittings for my nitrogen tank, and talked to him for a few minutes regarding my issues. He gave me a few great ways to check the compressors (for much the same symptoms as you have already mentioned).
I aired up my tank to about 100PSI and then shut the car off. I took the intakes off the compressors and plugged the inlet with my thumb... I took my thumb off one of my pumps and it made a loud WHOOSH. Air was coming back through the check valve. So there's the one problem.
Another suggestion he had was to see if my pumps were even creating pressure. I unhooked the lines from the tank and plugged the lines with my thumb to see if the compressor was doing its job. The compressor that was on the GOOD leader line isn't creating any pressure, and the one that was on the BAD leader line was building pressure just fine. I couldn't hold my thumb over the end of the line for more than a second before it blew my thumb off the hose.
So I had a bad check valve and one bad pump it sounds like. I was planning on just running one pump as a backup to my nitrogen tank, so I guess I'm not in too bad of a situation, but disappointed none the less that one of the pumps already seems to have given out on me.
Thanks again Shawn and Zack for helping me troubleshoot! Sounds like I've got it pinned down.
